Cleaning ugly oily floor hack saw mess 30 years worth...
Results 1 to 15 of 15
    Jul 2007
    Missoula Mt
    428
    15
    165
    Default Cleaning ugly oily floor hack saw mess 30 years worth...
    What is the easy/ best way to clean up the mess from a old hacksaw area? Hydrolic saw with a leak,cutting oil, rusty chips ect 30 years worth about, shop boy didnt do job, hi hi 20x20ft...cement floor and wall...Thanks Phil
    Southern Indiana USA
    326
    30
    203
    Would the area be OK for you to use a pressure washer? i.e a drain, nothing to get damaged from water, etc. I might try using a combination of emulsifiers or solvetns to break down the grease/oil followed up by detergents in a pressure washer.
    Mar 2005
    Kansas
    7,967
    491
    3801
    There are hand maneuvered rotary floor cleaners for power washers that do a pretty good job of containing the splash. They look about like a round small push mower. You still have lots of water to control, but a couple of squeegees should handle that. A good thing about the rotary floor cleaners is they take a lot of the reaction out of the nozzle. You can handle a gpm/pressure combination that you would never be able to handle in a wand.
    Sep 2005
    Oakland, CA
    2,693
    393
    774
    Soak it with solvent or mineral spirits, scrape with shovel, cover with absorbent- sawdust or kitty litter. Let sit a day. Suck that up. Then use Zep Industrial Purple - scrub it and suck it up.
    Mar 2006
    Wisconsin
    1,197
    14
    425
    I sprayed down my Racine saw with Gunk engine cleaner. Let it set a few minutes then pressure washed it with warm water. In this case the motor and electrical panel had already been removed for cleaning and upgrading so there was no need to cover them. I also tipped the saw on it's side and flushed out all the caked on swarf in the reservoir. The degreaser dissolved the crusty hydraulic oil so it could be flushed down the drain The swarf could be swept up and disposed of. Just make sure you clean up the swarf before it dries. Once dry it's hard to move and leaves stains on the floor.
    As a side note you probably should have fired the "shop boy" 29 years earlier. I was the one assigned that particular duty when I first started in a machine shop. Luckily it had been done on a regular basis before I arrived so it wasn't that big of a deal. To put it in the proper context is was a far more pleasant chore than helping my father (a plumber) clean up sewage spills from broken pipes.
  6. Likes kustomizer, Phil in Montana liked this post
    May 2019
    Michigan
    1,757
    560
    969
    I'm here to tell you that oil loves concrete.
    If it's been there for that long it will keep resurfacing IME.
    Clean it with muriatic acid and pressure washer, in 3 days it will be oily again.
    Nov 2014
    Florida
    4,723
    1824
    2266
    Quote Originally Posted by projectnut View Post
    Thats funny stuff there. A couple jobs ago they were so into environmental protection that all the machines that used coolant had to have a sheet metal box under them that was twice the volume of the tank to contain any spills.
  9. #8
    Nov 2013
    Eastern Massachusetts, USA
    5,743
    5318
    5434
    100% agree with Dan from Oakland. Scrape it up before trying to clean further. If it's really stuck I'd suggest a pneumatic floor scraper. I bought one from HF years ago for under a hundred and it holds up well if you keep it oiled with air tool oil. I bought mine for ice removal during one brutal winter.
  10. #9
    Feb 2013
    Northern califorina, usa
    378
    7
    132
    Quote Originally Posted by ChipSplitter View Post
    You got that right, oil permeates concrete. Long term equipment placement that spatters/drips etc oil just seeps into the upper layer of the concrete. We tried industrial chemicals ,hot high pressure washers, even knotted wire wheels. We finely hired a concrete grinding company to clean it up.
    I can't off the top of my head recall the correct name of the machine they used but it's the same machine they use to expose the pea gravel in concrete when polishing. They took about 1/8"or a little more off the top to get clean material.
  11. Likes J Grainger liked this post
  12. #10
    Apr 2018
    4,664
    2095
    Quote Originally Posted by dana gear View Post
    The sawdust will eventually soak up most of it. Enough so it doesn't look like an Exxon Valdez memorial, at the very least. You can help it along by adding some light solvent to the mess.
    And then your concrete isn't destroyed.
  13. #11
    326
    30
    203
    When we built our new shop in January we had the floor sealed and painted with a water based epoxy with a "high percentage of solids" (sales lit statement). Damn glad we did, it is SO much easier to keep clean. Our old shop was bare concrete and it was saturated with oil under several pieces of equipment.
  14. #12
    Oct 2009
    Oregon
    4,967
    5386
    2547
    I have this small powered scrubber I bought at a garage sale that uses 2 6" brushes and that combined with purple power or ZEP floor cleaner does a decent job on the floors I've had to clean.
    The powered scrubbing makes things much better/faster.
  15. #13
    Mar 2006
    Wisconsin
    1,197
    14
    425
    It seems there are different rules for different industries. There's a do it yourself car wash about a mile from our house. You'd be surprised what goes through there. I've seen everything from farm tractors to construction equipment to off road vehicles go through there. Sometimes the walls and floors are covered with all kinds of grease, oil, goo, and who knows what.
    That's where I cleaned my saw. I asked before I did it to avoid potential problems.
  16. #14
    May 2006
    Seattle
    2,149
    51
    435
    The degreaser dissolved the crusty hydraulic oil so it could be flushed down the drain.
    Where I live, that is a huge no-no. A better way is to plug your drain and use a shop vac to suck up the effluent, then go out in a field and dig a hole and pour the waste fluid into it. The critters in the soil will eat it eventually. Way better environmentally.
    metalmagpie
  17. #15
    Jul 2007
    Missoula Mt
    428
    15
    165
    Thanks guys, I scraped up the top stuff, used diesel fuel and scraped more, added floor dry and scrubbed.... let sit 3 days swiped up floor dry... then purple soap and water... a lot better but the oil is weeping up so now on to saw dust...Phil
