I am building a small gearbox using M0.5 gears with 2.5mm bores. There is going to be a clearance fit between the gears and the shafts. The gears will be sliding on the shafts like on the gearbox shown in the attached picture.
Before I get the gears made of ISO 45C steel I would like to get them 3D printed in resin for a prototype.
For shafts I am going to use 2.5mm h6 dowel pins.
My question is how do I create the right clearance between a shaft (dowel pin) and a 3D printed resin gear. Can I get the bore in a gear printed to 2.4mm and then ream it with H7 2.51mm reamer? That way the clearance would be similar as in H8/f7 or F8/h7 preferred fit.
The reamer: GARANT NC reamer H7 2,51 mm
