I'm working on a clutch plate for an oil field service rig, it's for the draw works. That means it is in a big winch, the plate diameter is 21 3/4 inch, I would like to know what kind of material was used in the steel backing plate? Before you all say buy new, forget it, the manufacture only made five of these 60 years ago, there are none. the plate is .068 thick I was looking at using A514 but I can not get it in that thickness. What steel is available in 14 or 15 gage with good flex properties ? The friction material is no problem we can get that from a shop in Texas.
