Sierevello1
- Nov 16, 2009
- Indianapolis, IN
I have an older Anilam Crusader M 3 axis mill. I have some bad caps on several of the boards that are starting to give me issues. I have attached a few pictures of the ones I need to replace. One is marked 4u7 35, which I assume means 4.7uF and 35v, and it appears to be a Tantalum cap.
The other is green with a red dot on top and is marked 103 M5 and the board is marked .01 where the cap goes. I'm not sure if this is a ceramic cap or also Tantalum.
Any help in identifying these are appreciated.
Thank You,
Steve
Thank You,
Steve
