tonymor
- Feb 9, 2017
- Chambersburg PA USA
We've got a Leadwell LTC-35 that's about 3yrs old. 15" Chuck, 12 station BMT-75 turret.
Mostly we don't get too much trouble with vibration. We can generally rough, finish turn and thread no problem. We do get vibration on some parts(sometimes) when we try to get a decent finish on grooves with a 3mm iscar grooving tip in a 1-1/2" tool holder on 2" and 3" 1045 bar.
Right now i'm working through issues machining 3" induction hardened 1045 chromed bar. We keep breaking our kyocera ceramic tips. These have worked pretty well for us on 65mm & 50mm hardened chrome from another supplier at identical speeds, feeds & DOC. We just measured the hardness to be 68Hrc. The spec from our other material is 55-60. I think the hardness is the biggest problem but we are also seeing some vibration and i think with about 5" of stickout we should be rigid enough.
This machine has been crashed a couple of times. One pretty big crash in x where we had to re-allign the spindle.
What i'm wondering is are there any simple checks i can do on the different machine elements to see if these might be contributing to the vibration we see?
I'm thinking about investing in some CBN tips but want to make sure we don't have a machine issue contributing to vibration that could kill these tips.
