My place of employment is looking to replace our 16 X 40 Bridgeport EZ path lathe with something newer and more well supported.
We are a prototype shop that does almost no production, our need for a CNC lathe is driven by part complexity. Our shop has ProtoTrak CNC mills, the EZ path lathe, a Mitsubishi WEDM and manual mills and lathes. We predominantly use the conversational programing when available but also use Surfcam software if part complexity requires it.
I have been focusing on conventional bed lathes, with a tailstock and steady rests, but might be open to other options. I would like to stay in the same size class but might be willing to down size a little. In the past few years we have been doing a lot of complex, deep internal bores so having a spindle that will run at 50 RPM would be an asset for us. We need to be able to run G code and have a post for surfcam, but having conversational programing would be a definite plus.
And the kicker, the shop is in a basement so the machine needs to be able to be disassembled to fit through a 48" door and into a freight elevator that measures 60" X 96"
I have been looking at Southwest's 1630sx and 1845sx and Haas's TL-1 and TL-2.
Any suggestions of other machines that might fit the criteria or any personal experience with any of the suggested machines would be appreciated.
