Hi,
An electronic engineer here, weak on mechanical engineering know-how.
I've a case about 70mm cubed and a relatively low quantity of around 200 (initially). Long term view is unknown until initial sale figures can predict it. Certainly I don't want to order 10,000 up-front.
It looks like CNC is the way to go as I believe casting could have additional expense (sliders?) due to the strap groove going around the side. The case is to be annodised or similar which I'm told is another benefit of CNC (don't need additional polishing).
I ran it through 3dhubs and it's come back at about £3k for 200 pieces. Can I ask;
1. any cheaper and respected sources people use for CNC?
2. any hints and tips you can suggest - I'm learning and soaking up everything I can pick up on.
