I make broadheads, don't make a living out of it, but enjoy it and as most here, try to improve the process.
They are made from 1055, stamped out in an incline press, heat treated in house by me, and sharpened on a pretty big surface grinder. Theya re 1.2mm thick, and a couple of different shapes, 75mm long and 28mm wide and the other about 50mm long and 28m wide, with cutouts on the centre for the ferrule.
I heat treat about 2000 blades at a time, in racks and then put them in a cement mixer to descale before tempering in 2 cycles in clamps, ending up at 52-54rc.
I have for the past few years since i bought the business just had the bare steel finish, sprayed with a product called dry coat, a water soluble rust preventative.
I've always hated the visual look and have looked at various coatings, even went and bought all the gear to cerakote them in house, but the prep work was too time consuming, having to bead blast every blade with those thick gloves was a knightmare.
I decided on black oxide a few weeks ago and asked if he has any issues with hydrogen embrittlement and was told no. Although i didn't specifically ask what he prepped them with.
I have just had a few snap in the jigs on the grinder and a few snap while re-sharpening on a stone.
I have since found out the prep is hydrochloric acid at 33%, then black oxide coated, the hydrochloric is the issue i think, as they aren't baked afterwards.
Bearing in mind i have to courier them a couple of hours each way to get them done, and sent down about 35kg(77 lbs) of blades to be done at once.
Anyone else get bulk flat parts prepped good enough for coating without using acid?
Only thing i can think of is a rotary sandblaster, but don't know of anyone that does it.
I'm in Australia too.
