Grizzler73
- Mar 19, 2019
Hi Guys
I'm new to the forum having just brought a 1953/54 Mk1 Student, I had been told by the seller that the clutch was toast and upon investigation I found that the clutch shifting fork (which was very worn) was loose on the shaft with no pins inserted and was missing the bronze pads, I assume there is a 2 part collar that attaches to the back of the clutch that the fork sits in and a nut on the end, so when you pull up the lever at the front the fork pushes the clutch in to engage drive? there is clutch plate type material on the front face of the cone shaped clutch.
So...
1. Does anybody have a diagram of this set up as the Student manual does not show this arrangement.
2. Does anybody know if/where I can get these parts?
By the way I'm in the UK.
Thanks for any help, I'm sure there will be more questions coming!
So...
