Colchester Triumph 2000 1980's Square Head lifting
Results 1 to 3 of 3
    Jun 2007
    Western Australia
    228
    10
    9
    Default Colchester Triumph 2000 1980's Square Head lifting
    Soon I will be collecting a Colchester Triumph 2000 around the last of the square head with a foot brake (correct me if I'm wrong). Can anyone tell me if these machines use UNC/UNF threads or Whitworth threads. The reason I'm asking is because I was going to lift the machine with a eye bolt in the bed, if that is the correct way?
    My Colchester Mastiff is a late 70's machine and that has all whitworth threads.
    Apr 2004
    Modesto, CA USA
    8,805
    1735
    My Harrison M300 is all metric from first build in 1972? to today. I think they were all part of the 600 group by then. The factory inch version is a weird metric/english lead screw. Something like 35mm diameter but 10-tpi. The metric one would be the same 35mm diameter but a metric thread spacing.
    Bill D
    Dec 2012
    AUSTRALIA
    4,837
    29
    1748
    In fact,you will find all Colchester lathes from the 60s onward have UNC threads...the only exception being a few pipe plugs .
  4. Likes swarfless liked this post
