Hi to all,
I am about to finally level my Triumph 2000. Did a very fast check yesterday, trying to find where I should level off. The tops of the front and rear V ways don not seem to be at the same height. So, it will be the flats I guess. But, from a first check with an indicator off my (worn top) cross slide, I would not determine two flats of the same height!
I would assume that the wide flats should be used and not the clearance slots.
Check my manual, I have a scanned copy that is very bad in quality
The insert in the picture is what I want exactly, I think it confirms leveling with spacers off the wide flats.
Can someone confirm, or point me to a better scanned manual? First gen (footbrake) manual has this information, the later one not.
Many thanks
Thanos
Many thanks
Thanos
