jim_cliff11
- Dec 12, 2013
- UK, Cheshire
Hi,
I have recently bought a Colchester Triumph 2000 lathe with a 50" bed. The lathe needs some work, but we paid next to nothing for it. It has dual metric / imperial dials, 16 spindle speeds, the 6" D1 camlock chuck mountand foot pedal to brake the spindle.
Basically, the thread cutting lever will not engage. The half nuts would not engage with the lead screw. To cut a long story short, we stripped the gearbox off the apron and removed the half nuts and leadscrew. The problem is that the leadscrew is metric with a 6mm pitch, yet the half nuts are imperial 1/4" pitch.... hense they wont mesh!
When I spoke to Tony at Lathes.co.uk and a colchester lathe parts company down south they both told the lathe serial number indicates the lathe was imperial coming out of the factory. However we have a metric leadscrew and metric swing arm gears. Under the leadscrew direction handle on the main gearbox it is even printed onto the fascia 6mm. This makes me think the lathe is actually metric.
Anyway, I have found a set of metric half nuts to fit, but before I buy I need clarification. Neither the leadscrew or imperial half nuts look new on our machine, so its hard to tell which one has been swapped. Someone has either fitted a metric leadscrew on an imperial machine, or a set of imperial half nuts on a metric machine. The serial number says imperial, but everything else points to metric.
My gut feeling is it is a metric lathe with the correct 6mm leadscrew, and the half nuts are at fault. If I fit metric half nuts to match the metric leadscrew yet the lathe does on the off chance turn out to be imperial, would this work? Or would the gearing be to cock. Thus, meaning I then have to invest in a new imperial leadscrew.
Sorry on the long winded explanation, but hopefully I've explained myself without to much confusion.
Can anyone help?
Jim
Can anyone help?
Jim
