I'm looking at purchasing a MACC cold cut saw, however, the motor is two speeds 2800 and 1400. When it's at 2800 its 3hp and when it's at 1400 its 2hp.
So I have a 2.2 kw phase converter will it run it in both speeds . Also what are the different speeds for what material and type should i be using for different speeds, I want it for cutting mild steel
