I am using a caliper. A really good one from The Home Depot (a little sarcasm there).
Maybe that's where my confusion lies.
I'm just a lowly mechanic, not an engineer or a machinist. But I've taken on the task of trying to modify a machine that has had an issue from its inception 60 years ago. The issue has never been addressed. I had the idea several months ago and to date I've made a prototype assembly by hand from scraps of material I had lying around my shop. It was very crude and only worked twice before it failed, but it worked. The theory is sound.
So now I'm at phase two of the project. Build a precise prototype from the correct materials and with the correct dimensions. I'll walk into a local machine shop and hand them my drawings and they'll make my four major parts for the prototype. When they hand me my parts and I assemble them onto my machine and it doesn't work, it'll be my fault because of something I overlooked or was ignorant about. They made the parts to my specifications so I have to know what the specifications are.
The first thing I've learned from y'all is that I will not trust the caliper I am using. I'll use it as a guide but for nothing more henceforth.
The part in question, to which this thread relates, will have a 1.5" ID plastic sleeve bearing pressed into it. As I understand it, once the bearing is pressed into the part, the ID will be at the nominal 1.5", so I will have the shaft made accordingly. What I don't know, because I'm not an engineer, is the inside diameter of the part in which the bearing is pressed into. The manufacturer of the bearing gives an OD of 1.656". If you were going to bore a hole in the part for the OD of the bearing, what bore diameter would you use? And once the bearing is pressed into the part, and its ID diameter should now be 1.5", what OD of the shaft on which the bearing will pivot should I have the machine shop turn it to?
The shaft will take about one second to pivot 90 degrees. Then another second to return to its home position. But during normal operation, the shaft and bearing will turn in unison. It's only when something jams on the machine that the bearing will need to pivot on the shaft. There's not a tremendous amount of load. The bearing needs to be a slide fit on the shaft but with a close tolerance. And, if the design works as planned once I get the bugs out, and I actually get to produce and sell the assemblies once testing is complete, I need a design that I can just press the bearing in place and assemble it onto the shaft. I won't have the luxury of boring each bearing to fit each part. So I need a good design with close enough tolerances so I can just slap (so to speak) the parts together into an assembly and ship them off to consumers.
If anyone has anything else they care to offer, I would greatly appreciate any advice you care to give. I came here to seek the advice of professionals. I think I'm in the right place. You may have already answered my questions so I will go back and carefully read each response again. Thank you all very much...
