Hi all,
I've been doing some research on compressors and have a few general questions regarding continuous run setups, and how to identify them. I think I have it all figured out (ha!), but could use some confirmation. Simple questions I think. I am asking in general about popular industrial compressors (IR, Quincy, Saylor-Beall, etc).
Questions:
If a 2 stage compressor has brass lines connecting the top of the cylinders to each other and then off to something else, does this indicate that the compressor has head unloaders? Is this universally true, or can they be for something else?
If the above is true, is the "something else" above a pilot valve connected to the high pressure tank, which when triggered by high pressure opens the top of the cylinder to the atmosphere (so there is no pressure in the cylinders)?
If you have head unloaders are there also typically centrifugal unloaders? Is the amount of unloading the same? Or asked another way - is a head unloader going to start easier than one without head unloaders?
I am trying to determine the best way to use 50CFM at around a 70% usage cycle by grouping 5 or 10 hp compressors (for a 200# steam hammer). I'd like to keep the current surges low since I have 100amps at the moment. I'm considering the constant use since I think the compressors would cycle a lot, so I'm thinking that if that is the case it might be better to be able to switch modes (during heavy use run continuous, but when I'm not using it as heavily go to auto start/stop). Searching on CL there are usually pictures, but little other information, so I'd like to be able to pick up on the key identifiers without having to email.
I appreciate any help.
Don
Questions:
Don
