Compressor lugging while filling...diagnosis?
Results 1 to 12 of 12
    Jun 2002
    CANADA
    British Columbia
    2,644
    2152
    Default Compressor lugging while filling...diagnosis?
    Good morning All:
    I have a Gardner Denver 2 stage reciprocating compressor vintage 2001 that's recently started acting up.
    When I drain it completely and then fill it, it starts lugging badly and the belts squeal at around 60 PSi, then it returns to normal and fills the rest of the way to 160.
    Sometimes it does it sometimes not.
    It's got 5 ponies and the flywheel speed is getting down to within maybe a couple of hundred RPM.
    It's got a 2.5:1 reduction ratio and the nameplate motor speed is 1725
    I took the belts off, degreased them and the pulleys, dressed the belts with belt dressing spray, retensioned them and fired it up again.
    It's not much better.
    The crankcase has oil (recently replaced), I drain the water daily, the compressor turns over with what feels like acceptable compression with free movement at bottom dead center and no evil noises during a manual stroke, the motor spins freely...all seems to be good in that department.
    So I don't think it's the crankcase bearings or the motor bearings.
    Short of taking the whole thing apart to try to find a problem, any ideas what might be happening.
    A stuck delivery valve to the high pressure side maybe?
    Are the valves typically accessible from the outside of a recip or do I have to tear the whole goddamn thing apart?
    I've never had a 2 stage recip compressor apart...where do I start?
    I assume I have to get a gasket kit first before I start undoing bolts.
    Do these things have piston rings like a car?
    Do the cylinders typically get a hone before the whole works goes back together?
    If this is going to be a major undertaking, I'll probably have it serviced by the seller rather than farting about with it myself.
    So my question is mostly about what kind of effort this is likely going to be.
    Cheers
    Marcus
    Mar 2006
    Winnipeg,Manitoba
    123
    28
    The place to start will be the check valve. That will be between the line going into the tank, and the tank itself. Usually located just outside the tank. There are multiple styles of checks, so a piccy would nail it down. Penetrating oil and a calm disposition go a long way.
  3. Likes Limy Sami, Bobw liked this post
    Feb 2011
    BFE Nevada/San Marcos Tx
    1,296
    1202
    710
    If it has reed valves you would have to pull head to clean or replace them, if it has disk valves, they can be cleaned or replaced without pulling the head. Yes the pistons have rings just like a car engine, but I don't think you need to worry about that, yet. Check your check valve first, and get some pics.
  5. Likes Limy Sami liked this post
  6. #4
    Jan 2007
    Norfolk, UK
    19,056
    14558
    14661
    ''When I drain it completely and then fill it, it starts lugging badly and the belts squeal at around 60 PSi, then it returns to normal and fills the rest of the way to 160.
    Sometimes it does it sometimes not.''
    I'm in the check valve camp, sounds like it could be sticking and / or some sort of blockage that needs 60+ psi to open it.
    Another thought - is there any type of rubber hose between the pump and receiver (sorry - tank)
  7. Likes Bobw liked this post
  8. #5
    Jul 2011
    Americus, Georgia
    417
    538
    131
    Check valve is about the only component to fail and give intermittent blockage. The gauge you are reading must be between the check valve and tank. A gauge between the compressor discharge and check valve would show high pressure when the lugging occurs. Remember that pressure is resistance to flow.
  9. #6
    Dec 2012
    AUSTRALIA
    2,427
    10
    763
    Pretty typical symptoms of belts slipping.....belts slip until they get hot and sticky,then grip and off she goes......so first replace the belts,even if they look OK,and tension them properly......while doing that ,try the belt in the small(motor) pulley section.....if the new belt fits down in the vee to the bottom,then the pulley will need replacing.......Ive seen quite new pulleys worn out,.....Chinese made rubbish ,even on a domestic machine.
  10. #7
    Sep 2014
    Georgia
    353
    264
    128
    If you have a clamp-on amp meter see if it is drawing too many amps in the trouble zone. It is probably a valve problem that is keeping the high pressure cylinder from doing its part of the work.
  11. #8
    Mar 2006
    Auburn CA
    435
    5
    39
    I second putting a current meter on it. I also agree if it is lugging down the check valve is a good place to look.
    But if it is slowing down as much as you say there should be smoke coming out of the motor. At way less slow down than you have stated the motor would be drawing nearly locked rotar current. This should trip your over current protection in a short amount of time (perhaps a few seconds). The ammeter will provide instant clarity to this issue.
    My first thought was also slipping belt as that is the only way I could envision that much of a slow down with out tripping the over current device. But the RPM change at 60 PSI suggests a different root cause than a slipping belt.
    First step remove the line from the output of the compressor. If it spins free the problem is down stream.
    Bill
  12. Likes Limy Sami liked this post
  13. #9
    Jul 2012
    Washington
    2,982
    1165
    1232
    When I first fired up my HD 4hp 2 stage compressor something was clearly wrong. I found out the rubber plug was never removed from the exhaust port before assembly and ended up at the check valve plugging it up. The compressor didn't bog down much at all and it's just a cheapie.
  14. #10
    Oct 2005
    16,087
    Trouble with the valves between the stages ?
  15. #11
    Jun 2002
    CANADA
    British Columbia
    2,644
    2152
    Gentlemen, thank you all for your insights.
    I pulled the check valve, brushed the accumulated crap off it it and tossed it into the ultrasonic cleaner.
    All seems to be good again.
    We will keep fingers crossed and pray to the Compressor Gods, but it's run for a full day now and she's chuggin' away with no bogging down and no squealing.
    Cheers
    Marcus
  16. Likes Gordon Heaton, paul39, Bobw, Limy Sami liked this post
  17. #12
    Jan 2007
    Norfolk, UK
    19,056
    14558
    14661
    Quote Originally Posted by implmex View Post
    Cheers
    Marcus
    Having an ultrasonic cleaner's cheating Marcus
    Well done mate
