Spiderzmobile
- Jun 5, 2017
PLEASE HELP!
I recently inherited a 20 Gallon Compressor, which does work (I tested it, before tearing into it); and it's something bigger than my 6 Gallon one
Unfortunately, this thing sat for quite a long time without being drained (i.e. it had a good amount of water inside and plenty of time to rust it up )
The drain cock was frozen shut so I drilled it out (along with the threads), I want to replace the "nut" that the drain valve screwed into but it doesn't want to come out!
I've been:
1. Spraying it down with penetrating oil
2. Using an impact driver and 1-1/8" Socket to no avail
3. Applied heat with a torch
Any thoughts... Prayers... Suggestions?
I've been:
