crossthread
Titanium
- Aug 5, 2004
- Richmond,VA,USA
I have a friend who works in the laboratory equipment field. I often machine up a doohickey for him to get something up and running. He also works on the ultra-low freezers and cryostats. The problem is that to replace a compressor, filter dryer, accumulator or something like that he has to silver solder the part in. A lot of the labs he works in will no longer allow an open flame so his acy/ox torch is out. He asked me if I had any ideas how he could heat up copper pipe to brazing temperature without a flame. I thought of the induction heaters and they are available with a wrap around design (so you can get it off the tubing after it is soldered) but cost an arm and a leg. Way out of his budget since he is a one man company. I looked up some homemade units but I was not impressed with ease of construction since they require tuned tank circuits and I don't have the equipment for that. I am thinking along the lines of a band saw welder. Basically a big honker step down transformer with some clamps (possibly with carbon pads) that could be placed on either side of the joint. It may be that copper is too good a conductor and will not work. Any ideas? Thanks.
