converting hydraulic motor specs
Page 1 of 2 12 LastLast
Results 1 to 20 of 34
    Jan 2007
    Florida
    982
    110
    365
    Default converting hydraulic motor specs
    group 2 bsp ported gear pump 6cc
    what is that in american english? having trouble finding where to convert displacement to gpm
    Feb 2014
    Sunny South West Florida, USA
    2,226
    9081
    2631
    Quote Originally Posted by cg285 View Post
    Displacement per revolution x RPM?
    Mar 2011
    Denver, CO USA
    11,532
    45
    5291
    You need the speed.
    6cc=0.37 ci
    231 ci per gallon
    Go from there.
    Jan 2007
    Florida
    982
    110
    365
    Quote Originally Posted by Miguels244 View Post
    You need the speed.
    6cc=0.37 ci
    231 ci per gallon
    Go from there.
    when i am looking at specs to buy one rpm is not mentioned. on this side of the lake they are rated @gpm, the other side at Xcc. would not the gpm change with speed also?
    Mar 2011
    Denver, CO USA
    11,532
    45
    5291
    You need to know the speed you will be running the pump at.
    You also need to know the speed to convert from gpm into displacement.
    Oct 2005
    11,003
    17934
    5813
    Maybe just post a link to the motor.
    Jan 2007
    Florida
    982
    110
    365
    Jan 2007
    Florida
    982
    110
    365
    i converted 6.3cc to .384ci and found a listing for a pump @6gpm. looking at that link i assume it refers to liters per minute which comes to 2.3gpm @1500, so 4.6gpm at 3000 which doesn't match the other at 6gpm
    maybe 4.6 rounds off to 6
    Oct 2005
    11,003
    17934
    5813
    The link you provide clearly stated "at 1500 rpm" I would not extrapolate
    that up to 3000 rpm.
    Jan 2007
    Norfolk, UK
    17,240
    12905
    12497
    I agree and click on the specification heading
    That pump has a max speed of 3500 rpm which I worked out to 22 l /min or 5.8 US gal / min
  11. #11
    Oct 2005
    11,003
    17934
    5813
    Quote Originally Posted by Limy Sami View Post
    I see that now,(separate max speed listed up top) usually I see the spec's given for the max conditions.
  12. #12
    Jan 2007
    Florida
    982
    110
    365
    my american link said [email protected] [email protected]
  13. #13
    Jan 2007
    Norfolk, UK
    17,240
    12905
    12497
    And that depends on who did the maths,
    A tip for conversion, forget about cubic inches etc etc it confuses the picture -stick to liquid volume 1000 cc's = 1 litre. 1 litre = 0.264172 US gallons
    Believe it or not, volume per rev and RPM are the same both sides of the Atlantic
  14. Likes digger doug, TeachMePlease, steve-l liked this post
  15. #14
    Jan 2007
    Florida
    982
    110
    365
    would there be a problem is the l/gpm was higher than specified? like on a dirt bike it's all in the throttle
  16. #15
    Oct 2005
    11,003
    17934
    5813
    Are you asking to push the GPM higher than max rated ?
    What are you trying to do with this motor ?
  17. #16
    Dec 2004
    uk
    12,797
    3693
    5792
    More gallons per minute at a given pressure takes more tourqe to pump, theres no free ride on this stuff. Most hydrulic pumps will extrapolate up and down pretty linearly, there fixed or nearly fixed displacement devices, its only at very low speed will they fall off, generally as speed increases they pump more as leakage reduces.
  18. #17
    Jan 2007
    Florida
    982
    110
    365
    not push the gpm higher but purchase a pump with a higher gpm rating (which is more readily available)
    small engine (13hp) powering 3 rams and one hyd motor.
  19. #18
    May 2017
    FINLAND
    1,139
    303
    542
    You need different belt/gear drive ratio if you want to get the same pressure as you get with the smaller pump.
  20. #19
    Jan 2007
    Florida
    982
    110
    365
    Quote Originally Posted by MattiJ View Post
    so the answer is no, don't use a higher gpm pump - correct?
  21. #20
    Sep 2017
    South Carolina
    236
    203
    216
    Ya'll dont use metric RPM?
