Have a 60's era horizontal mill with a vertical head, both spindles are NMTB 40. My CNC has CAT40 tooling. Being able to share oddball tools as needed would be quite nice.
The PO of my mill made it sound like the drive lugs had already been swapped, or were capable from the factory of taking CAT40 tooling. A quick fit up the other night proved they are not.
I already have a piece of stressproof coming for longer drawbars (seemed like a reasonable material choice). So I am looking at what to do with the drive lugs.
My plan was to remove and keep the original lugs and simply make new "thinner" ones to accommodate the shallow notch ,regardless of the orientation, of the CAT 40 tooling. Suggestions on material? 4140 PH was mentioned elsewhere. I have some 4140 (Annealed) in the rack and could heat treat if I had to. Suggestions?
If it makes any difference, this is a 5HP machine and poised to do odd jobs, not heavy production machining. Read: I would rather err on the side of protecting the machine rather than ensuring I can run the the spindle at 125% load for hours on end.
