Coolant or cutting oil for drilling 6Al4V titanium?
Results 1 to 8 of 8
    Oct 2005
    CANADA
    Ontario
    902
    153
    284
    Default Coolant or cutting oil for drilling 6Al4V titanium?
    Drilling 4" long, 1/16" diameter holes in Ti. Only have a dozen parts to do so it's not high production. Using Dormer A 9401 & A977, cobalt, 130* split point drills. Have a good feed/speed/peck cycle.
    Did a bunch of searching here and elsewhere and am confusing myself more than anything. Some recommend a cutting oil such as Moly-D and others an oil based cutting fluid. Even others a full synthetic tapping fluid.
    Timet says "Chlorinated or sulfo-chlorinated oils and soluble-oil emulsions are satisfactory as cutting fluids". Does this mean cutting oils like Moly-D, TapMagic etc. as well as water soluble cutting oils like Rustlick and Hangsterfer's? I'm leaning towards a flood coolant for the long holes to keep things cool, would a full synthetic tapping fluid be better?
    Aug 2005
    Tucson AZ
    6,193
    8877
    2871
    Go with the flood soluble oil. Cutting Ti produces a lot of heat.
    Jun 2006
    Alabama
    1,863
    1074
    727
    A 4" deep 1/16" hole in Ti?!?!?!?
    Oct 2005
    CANADA
    Ontario
    902
    153
    284
    Quote Originally Posted by tdmidget View Post
    Higher than normal concentration to increase lubrication?
    Quote Originally Posted by Rstewart View Post
    Yessir! Hope to be straight to 0.010"...
    Jul 2009
    Utah
    52
    19
    Dear Terry,
    When machining Heat Resistant Super Alloys (HRSA), a great deal of cooling is needed to be really effective. Soluble oils are fine for this application, as well as a semi-synthetic coolant. If you are not limited by any approvals or restricted chemicals, I would suggest using a fluid which contains and EP additive such as Chlorinated Paraffin. If you cannot utilize Chlorine, than I would suggest looking into a fluid which is ester based.
    If you would like to discuss any additional options, please email me at [email protected]
    Best regards,
    Brett Reynolds, CMFS
    Sr. Applications Engineer
    Blaser Swisslube Inc.
  6. Likes Lambert liked this post
    Oct 2005
    CANADA
    Ontario
    902
    153
    284
    Thanks all for the input, decided to go with Rustlick Pro CF...
    Jun 2006
    Alabama
    1,863
    1074
    727
    That is 64x depth to dia ratio.... I really don't see this coming out too well. Without through spindle coolant, how is this even gonna work?
    I suspect we will be hearing more about this. Either way Good Luck
  9. #8
    Oct 2005
    CANADA
    Ontario
    902
    153
    284
    Sounds crazy I know but I was able to do a couple parts manually and they come out well, took LOTS of patience to peck drill. Have added a Z axis to my lathe to better do the job:
