clarnibass
- Dec 23, 2015
Hi
English is my second language and I'm trying to find the correct term in English for something.
It is where there is a connection (joint) between two tubes, where one has an enlarged short length of "ring" at the end (either by forming or brazing, etc.) and the other side is attached inside it. What is the name of that larger diameter end "ring"? I'm pretty sure it's not "ring", and "outer part of the overlap" doesn't sound right...
In case it's different, there are two situations.
One is where the two sides are attached e.g. soldered, glued, threaded, etc.
The other is where the parts are not attached e.g. just sliding in.
I don't know if this would make a difference to the term used.
