Counter Sinking Questions - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 48 of 48
  1. #41
    Jan 2013
    USA , New York
    The best Countersink by far for an application like this is a Vernon Counter-bit. They have been around for many years. It's a cone piloted countersink with a spade drill type blade that is exposed when pressure is placed on the cone. The cone pilot along with a radial relieved blade increases rigidity to eliminate the chatter. They are made by Vernon Devices.
  2. #42
    Oct 2005
    22,016
    Quote Originally Posted by AimPrecision View Post
    You mean "I make/sell them" ......
    Tapping Sequence
  3. #43
    Apr 2021
    Wisconsin
    This is going to sound jankie, but before I had a whole machine shop in my back yard I was messing around with projects in a small garage and had the exact same issue as the OP. Small bench top drill press with high speeds and absolutely no rigidity. The fix was to place a wood block between the table and base to allow more downward pressure, and then use a cordless drill chucked onto the 1/2" shaft of the motor to turn things slow enough to get the job done. I had to clamp the workpiece to the table to free up a hand to work the cordless drill, but was able to make many 1" countersinks in heavy 4140 plate. Single flute CS give me the best results in light duty setups. Only works if there is motor shaft sticking out above the motor pulley. Make sure its unplugged before you start, and try at your own risk.
  4. #44
    Jun 2012
    Idaho
    3,198
    1776
    2102
    Quote Originally Posted by jscpm View Post
    Countersink the cone first, then drill afterwards. Do not apply a countersink to an already drilled hole.
    wtf ???????????????
  5. Likes Bobw, Strostkovy liked this post
  6. #45
    Jul 2019
    Florida
    4,282
    4105
    817
    You can toggle the on off button as a try even with cutting fluid which you should use anyway IMO. For the cutters sake.
    Get down to about .100 and turn off the speed and let your feed find a non chattering mid range. This is sort of a trick really yet I have used it many times. I only used it when I had no good alternative to get it done. A lot depends on the rigidity of the drill press and the setup. The tool CS should of course be good to start with.
  7. #46
    Jun 2012
    Michigan
    13,814
    4696
    4973
    Most multi-flute CS should run at about 300 RPM to avoid chatter, single flutes can run faster/better.
    Small drill motors are often too fast.
    Check to see the screw heads need 45* many are not that angle, eyeball check should tell. 90* and 82* are common.
  8. #47
    Oct 2017
    1,319
    419
    449
    Keep in mind a mag drill is about $800 and does an absolutely wonderful job at countersinking.
    Just evaluate the cost before you get too carried away modifying your drill press or looking at other solutions.
    We do all of our 1 1/4" countersinks on a mag drill stuck to a welding table.
  9. #48
    Nov 2012
    Wisconsin
    115
    291
    14
    Quote Originally Posted by Terry Keeley View Post
    Not sure what countersink you're using but I've had great success with these:
    Series Display - M.A. Ford
    Those things chatter like crazy.
