Cracking at thread flanks?
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Aug 2014
    United States
    25
    14
    Default Cracking at thread flanks?
    I’m getting this mysterious cracking on my threads in C37 alloy steel bolts I was single point threading on my manual lathe. Any ideas why? Tools were HSS and cutting fluid was used. Changing the sfm didn’t make much of a difference.img_1352.jpgimg_1351.jpg
    May 2009
    Canandaigua, NY, USA
    3,017
    151
    1381
    I'm guessing you were plunging straight in. Probably need to come in at 29 degrees, make the tool sharper and maybe more relief angle. It's very easy to roll the edge of a tool while grinding it, giving way less angle than you thought you had, which makes it rub. What's the cutting fluid? I'd want a decent oil, probably animal or veggie based. My go-to on the manual lathe is Monroe Cool Tool II or Crown Buttercutt.
  3. Likes Gordon Heaton liked this post
    May 2019
    Michigan
    1,471
    425
    671
    Can you post more pics? It could be a wide range of things such as:
    tool off center
    compound not set at 29.5 degrees
    wrong tool or dull tool
    lack of rigidity in tool or workpiece
    spindle running in reverse.....
  5. Likes motion guru liked this post
  6. #4
    Oct 2005
    17,769
    Cracking or tearing ?
  7. Likes Matt_Maguire, Bobw liked this post
  8. #5
    Aug 2014
    United States
    25
    14
    I don't know. What you see in the pics is all I can see.
  9. #6
    Aug 2014
    United States
    25
    14
    I was plunging. I can do all those things. I was using Tap Magic Xtra Thick. Lard oil is good for turning, but this was good too.
  10. #7
    Jul 2007
    UNITED KINGDOM
    5,029
    2857
    2474
    You say changing the SFM didn't make much of a difference. What was the SFM?
    Also, what is your infeed?
  11. #8
    Aug 2014
    United States
    25
    14
    Quote Originally Posted by Mark Rand View Post
    .005 on diameter per pass. I was about 40 SFM.
  12. #9
    Feb 2004
    peekskill, NY
    25,330
    5178
    At 0.005 plunge per pass, that's a lot at the end of the threding cycle. You had a lot of tool engaged in the work.
    Suggest you change over to 29 degree compound, feed with the compound, and the last few cuts should be 0.001 or less.
  13. Likes MattiJ liked this post
  14. #10
    May 2019
    Michigan
    1,471
    425
    671
    40 SFM with HSS isn't helping you any either.
    If you can justify it, get a carbide laydown or topnotch setup and run more like 200 SFM.
  15. Likes James H Clark liked this post
  16. #11
    Feb 2005
    9,262
    14980
    11109
    What the heck is C37. I figured it was some low carbon steel, and you were from Europe.
    Nope. Some Magnesium-ish thing?
    Either way. to me at least, looks like you are tearing. Kind of like a mild crap steel,
    or even an annealed alloy steel. Tools a little dull, speed a little low, and it all
    just looks like shit.
    I don't know the alloy, but either speed or sharpness, or both should give you a better
    looking thread. Rigidity could also play a part, she looks like she's kind of long.
  17. Likes adh2000 liked this post
  18. #12
    May 2019
    Michigan
    1,471
    425
    671
    I hazard a guess that it's a Grade 5 bolt which is 1045ish. Threads sure look like it.
    Seems some days it cuts nice and chips break up, then the next day you take the paint off the lathe doors from the chips wrapping around the chuck.
  19. #13
    May 2017
    FINLAND
    2,157
    586
    999
    Quote Originally Posted by Bobw View Post
    C37 as Rockwell hardness C37? That would be something like grade 8 bolt.
    100% agree with others, what OP is having is usually called tearing.
    Two ways around it: LOT more speed, heavier infeed or slower and smaller infeed.
    For something like 1018 the ”lot more speed” approach is usually only valid for CNC.
    Threading at 900 SFM calls for good reflexes if you do it on manual lathe
  20. Likes AD Design, Bobw liked this post
  21. #14
    Jun 2012
    Tennessee USA
    917
    612
    536
    Agree with others that it looks like tearing instead of cutting. How are your relief angles? Any sign of tool rubbing under magnification? Tool height at or just below center of axis? HSS is my personal choice over carbide in a manual lathe. I'll stone the top and sides to get a keen edge if the material shows tearing. What others have suggested about cutting fluid, less depth of cut, and increased speed (within safe limits to disengage half nuts) is good advice.
  22. #15
    Jun 2012
    Michigan
    11,669
    3983
    4150
    Come in at 29-30 so only shaving one side if the thread, as mentioned by Conrad .
    I like a bit or insert with some positive top, back or side cutting edge rake angle, any one realy helps.
    Amount of part hanging out...short or with the tail best.
    and that the tool holder more centered on compound and cross slide. I see many YouTube with the bit/insert way far to the left so to make the holding of bit/insert more tippy to the down force of cutting...
    Sharpness of bit or insert..sharp enough to shave your finger nail..
    Guess we should add how the chuck jaws are holding.. set deeper in the chuck might ofset any taper jaw effect...
  23. #16
    Oct 2005
    17,769
    What lathe ?
    Maybe post a few pix of the overall set-up
  24. #17
    Jun 2012
    Michigan
    5,201
    4778
    3148
    RPM is too slow and it's tearing.
  25. #18
    Jan 2007
    Flushing/Flint, Michigan
    8,779
    470
    7215
    Does not look like either to me. I see material reweld.
    Tearing itself is quite rare in metal cutting. This condition much more common.
    I think most call this tearing so perhaps I'm just fussy.
    The material that looks like poop was not there before the cutting tool came along.
    It came from a teensy tiny bit earlier around the part. Spacing of the lines and cut depth per pass plus tool geometry tell you the where.
    More top rake, more clear, more speed, more lube, coated tool, sharper edge. Pick your poison or better a few of them.
    I guess you just call all this "cleaner cutting".
    Bob
  26. Likes digger doug liked this post
  27. #19
    May 2011
    southern in.
    1,515
    2022
    406
    Get a good carbide insert and run it a lot faster than you want to.
    JH
  28. #20
    Oct 2005
    17,769
    What lathe ?
    Nothing yet ?
    A few pix would go a long way.
