Looking at replacing a (1993 vintage) 14 inch color monitor on a CNC lathe with LCD if possible. As per usual with these sorts of things the R,B,G and H,V connector is not standard DB15 (in this case DB9), but according to my Hz meter horizontal seems to be 30.5 kHz but vertical is only 32 kHz ! Is this possible it could be that low ? (normal vertical is 60 kHz)
The other curiosity is, if I reverse negative and positive meter wires, so that positive is on the ground pin and negative on the vertical pin, the vertical reads 52 kHz !
If you're wondering if the meter is no good, it's always read spot on in the past when pin outputs compared with known kHz values.
Tempting to think there is something wrong with the video board rather than the monitor, but the current CRT monitor works fine for about 15 minutes but then the slightest vibration (near the monitor, not the board...board is on the backside of the machine) will shut it down....or light tap on the flyback....so almost certainly the problem is with the monitor, not the board.
Anyhoo, if it really is only 32 kHz vertical, then I'm SOL on the LCD conversion...but just hard to believe anyone made one with that low a vertical kHz as late as 1993.
