CRT monitor gurus- 32 kHz vertical possible ?? - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
  1. #21
    May 2009
    Romania, Alba
    11
    Quote Originally Posted by Milacron View Post
    What the hell is "RO, Alba" ? Since the last post you've moved from the USA to Romania ?? Actually Romania would be pretty cool, but best to spell out the whole name
    ) Romania , Alba is correct !!!!!!!!!!!!
    USA was made on hurry
  2. #22
    Dec 2000
    South Carolina
    51,773
    3198
    6045
    Quote Originally Posted by mouldcugir View Post
    OK, but slow down, edit once more, and spell your own country correctly ! the English version anyway...otherwise you sound like a Star Trek character
    Are Maho's popular in Romania ?
  3. #23
    May 2009
    Romania, Alba
    11
    Yes they are, mainly DMG machines (Maho, Dekel , Gildemeister). Now seems that Mikron is taking part of the market but DMG leads the market (as far as i know)
  4. #24
    Apr 2011
    Berne, Switzerland
    @mouldcugir: I am trying the same with a MAHO MH400 / Philips 432 control and the CGA Converter ACV-011.
    But unfortunately I am only getting a "Blackscreen". What are the positions of the 4 DIP-switches on the ACV-011?
    Would be great if somebody could help!!
  5. #25
    Apr 2011
    CA, USA
    Default monitor dead MH800C
    Did you solve the problem on your MH400? I bought the converter GBS-8220, it's next gen of the ACV-011 converter, but I didn't get any picture. I ordered the old version now, since it should work. If you have any information what you did to get an LCD monitor working, please let me know.
  6. #26
    Dec 2000
    South Carolina
    51,773
    3198
    6045
    You guys may have to stop mucking around with those scan doublers and do what I did...for 450 bucks + UPS from AU
    http://www.practicalmachinist.com/vb...or-pix-162256/
  7. #27
    Sep 2016
    PORTUGAL
    8
    I have a MAH MH 300 C as CRT monitor, wanted to put an LCD, somebody help me, I do not know how to make the connections. I leave a photo of the links on the CRT
    (sorry my Inglish, is google traductor)
  8. #28
    Jul 2013
    banja luka
    Greeting
    do you have managed to connect lcd?
  9. #29
    Jul 2014
    The Netherlands
    8
    To summarize:
    The DB9 is wired as:
    1=GND
    2=Green
    3=
    4=Vertical sync
    5=12v
    6=Horizontal Sync
    7=Red
    8=
    9=Blue
    From the Maho schematics i found the following wiring: (note: the monitor has a female DB15, the cable a male DB15)
    The DB15 is wired as:
    2=BLUE
    3=GND
    4=GREEN
    6=RED
    11=Vertical Sync
    13=Horizontal Sync
    I first tried the arcade CGA convertor Arcade Game CGA convertor board GBS-8220 from aliexpress. This did not work on the Philips 432, i think because the Horizontal and vertical sync had not separate connections.
    Now i just received the ACV-011 CGA converter, which has separate sync inputs, but still no result.
    I double-double checked the wiring, it is as above stated.
    The ACV-011 manual gives ALL SWITCHES ON for separate sync, tried this, and other switch combinations, but nothing works.
    Will wire up now from the Philips 432 controller to avoid using the DB15 connection...
    The Philips 432 has a female DB9 video connector.
  10. #30
    Oct 2006
    Klamath Falls, Oregon
    3,698
    433
    1028
    CGA is 15.7Khz horizontal sync frequency with positive vertical and horizontal sync signals.
    As long as the control output matches those parameters, a CGA or CGA compliant display will work.
  11. #31
    Jul 2014
    The Netherlands
    8
    After measuring with the frequency counter i found the 15.7 Khz. I am colourblind for red green and had the green and Horozontal sync mixed up...
    Display is working now with the ACV-011, dipswitches all on.
    Thanks.
  12. Likes Milacron, Perry Harrington liked this post
