I am in the process of installing lights in an enclosed 12' utility trailer. I will be traveling to various venues sharpening knives. The power at these venues is outdoors, like an RV campground, accessed via a cord and a breaker panel inside the trailer with strip receptacles. Each light plugs into the strip receptacle and then goes to a switch. This is so I can turn each light on independently. I may have sun shining in one end of the trailer and not need the light on that end, for instance.
I wired in the first light this evening and flipped the switch and got a flash of light and a tripped GFI. Checked all connections and no luck. 1 light on the circuit, #12 wire in the extension cord, 4' 2-bulb light. High intensity ballast and T-8 bulbs. Not a cheap shop light, $80 ea. I have the light on a non-GFI circuit and it works fine. However, I am afraid that the areas where I park the trailer are all going to have GFI breakers because their power is on a pole outside for the vendors. Is there a work around for this problem? I know that this isn't a machine question but I also know the experience here is multi-talented.
Thanks in advance, KQ
