I'm curious about what everyone's perspective is to the current state of R&D machining. I went to trade school in the early 90's and worked as an R&D Machinist for the next 15 years. Quite a bit has changed since then. I remember in 2002 or so an Engineer came down with a prototype made from an SLA type process of a new product he designed. He was pretty blown away by the technology (3D printing). This was a part I would have normally made. That's when I knew it was the beginning of the end. I worked soon there after at a reputable local CNC shop for a few years. The owner didn't want to have anything to do with small quantities of anything cause there was no money in it (which makes sense). I since then moved into a new line of work. Fast forward to today and it seems like virtually all prototypes are 3D printed and when it needs to be machined, it goes to ProtoLabs (which is an amazing company - not sure how anyone can compete with those guys for R&D type quantities). The company I use to work for that I did a ton of R&D prototyping for has recently eliminated the machine shops from their locations (this is a multi billion dollar company).
So my question is, is this type of work a thing of the past? If you work at a company that designs/sells their own products, how has R&D machining changed? If you're a shop owner, is it accurate to say that most places pass on low quantity machining (less that QTY 5 for instance)? Do you quote that type of work or has that fallen off as well (due to lack of demand for it)?
Not complaining - things change. Just curious how things are these days.
