Planning to build a bed rack but still undecided whether to use aluminum or steel material. I have an old headache rack that I bought from 4WheelOnline and I'm planning to copy its thickness. Or maybe I should go with 1.5" square tubing with a .120 wall steel?
The rack will be the same height as the cab of my truck, so it's fairly large. Aluminum can be lighter than steel but it will also depend on the load-bearing requirements of the rack. Is it good to design the rack in a way that the load-bearing portions are made up using trusses of smaller dimension tubing? With that idea, more welding and fabrication should be done to the project.
