morsetaper2
- Jul 2, 2002
- Gaithersburg, MD USA
Is it possible to waterjet, edm, or laser cut thin sheets of solder to odd shapes?
I work for a company that develops laser systems. And one of the materials we use between bolted interface components to improve thermal conductivity are small sheets of .002 thick tin-lead solder (63% tin/37% lead). Most of the time we just use a couple pieces and its usually a rectangular shape and some clearance holes we cut w/ a straightedge, x-acto knife, and some hole punches. Pieces usually range from about a ½” square piece to a couple inches square, rectangular, or odd shape. But nothing more than 4-6 inch on the longest length. We get the raw solder in sheets & rolls 1-3” wide or thereabouts.
If the pattern is a little complicated we might have a template cut out of alum where we run an x-acto knife around the template to cut out. Works good enough, and we generally only need a couple pieces. We have even machined patterns with the sheet sandwiched between alum. Works fine, but is expensive. Working on a project were I will need some slightly complex shapes created and in quantities “more than a few”. So researching what might be possible via laser, waterjet, or edm. If that would be better/cheaper than hand cutting or machining sandwiched between alum sheet.
My concern w/ laser & edm is the solder would melt and the edges would thicken up. So wondering if water jet might be a better option. Anyone ever cut solder sheet? Can you recommend a process or someone w/ experience w/ that material?
Mark Long
Mark Long
