Cutting 3.25" Hole in Aluminum
Page 1 of 3 123 LastLast
Results 1 to 20 of 57
    Oct 2019
    72
    17
    Default Cutting 3.25" Hole in Aluminum
    I'm in need of some guidance without breaking the bank...I'm trying to decide on how the most accurate way for me to cut a 3.25 dia. hole in apiece of 1/2" thick aluminum would be with a floor mounted drill press which has a MT2 spindle...The hole I'm shooting for needs to be clean without any ugly in the cut walls...accuracy doesn't have to be precise since the part that will go into the hole I can adjust for tight fit in my Lathe...I have several hole saws of various sizes but I fear that the quality of the hole would be sub standard as far as the wall finish...My chuck on the drill will only go to 1/2" I believe however it may stretch to 5/8" I just have not pushed this limit...
    I have tossed around a carbide china hole saw set up specifically for the dia. hole but am concerned it may not be deep enough to cut thru the 1/2" plate aluminum
    My hole saws are the older style where you have a arbor and attach the hole saw of desired size and lock down the locking nut...They spin and not very accurately at all...
    Fly cutter???
    Thoughts???
    Paul
    Feb 2020
    Maryland
    225
    69
    Everything depends on the tools you have to work with.Since you mentioned a lathe, I would drill with a 3 1/8" hole saw in the drill press then bore to final size in the lathe. If you have a mill then you can bore to final size with it. If it won"t fit on the lathe and you don"t have a mill, since it is aluminum, you could cobble together a treepanning cutter for the drill press.
  3. Likes tylersteez liked this post
    Aug 2012
    California, Central Coast
    5,361
    2405
    2212
    Or clamp the part on the carriage and the flycutter in the chuck. Similar to using the milling attachment some lathes had...
    Jun 2006
    Kansas
    1,665
    331
    648
    Or set it up and bore it out using the lathe. I don’t think the drill press is gonna get it done.
    Rob F. Beat me
    Mar 2012
    Geilenkirchen, Germany
    2,914
    1626
    1532
    Paul,
    Send the job out to someone that has the tools or acquire the tools yourself. Anything else endangers you, the tools you are abusing and the work.
  7. Likes Pathogen liked this post
  8. #6
    Jun 2021
    UNITED KINGDOM
    10
    Like curve bits, opening saws throw directly into your drill and will slice through slight measure sheet metals like aluminum and steel. Utilize a piece of compressed wood as a patron for the opening saw's pilot bit and to secure your work surface.
  9. #7
    Oct 2005
    22,362
    Malco has the tool for you.
  10. #8
    Jan 2005
    Houston
    7,142
    1335
    4145
    All these 'bore it in a lathe' comments ASSUME the part will fit in a lathe....not a great assumption.
    If your drill press is especially good, you could try an annular cutter.
  11. Likes dcsipo liked this post
  12. #9
    Oct 2019
    72
    17
    Quote Originally Posted by steve-l View Post
    Paul,
    This has crossed my mind
    However I would like the learning experience of seeing if I can muster up something before I send out...
  13. #10
    Oct 2019
    72
    17
    Quote Originally Posted by GregSY View Post
    The part will fit on the lathe now that I'm visualizing more ways of loading it on a lathe
  14. #11
    Oct 2019
    72
    17
    A fly cutter seems reasonable from what I looked at last night before I went to bed
    I have never used a fly cutter
    Are you supposed to provide a hole first then gradually increase the cutter of the fly up to size increasing the hole dia. slowly while feeding?
    The first and foremost is safety
    But if I can rig something up on the cross slide that would hold this odd triangular shaped material in place and that is providing I can rig something up with my limited visualization I might be able to make the cut with the use of the lathe
    Ill try and come up with some ideas hopefully watching the YouTube videos and getting the brain working...
    Or
    A fly cutter in the Drill press? would be an option as well
    I like the thoughts of using the lathe better though
    paul
  15. #12
    Nov 2013
    Eastern Massachusetts, USA
    7,485
    6211
    6651
    Do you own a router?
    If so, one way would be to drill with a 3-1/8" hole saw and then use a flush trim bit in the router with a guide ring precisely bored to size in the lathe. A 1/16" cut in aluminum is well within the capability of a carbide router bit.
    Also make a stepped plug to center the guide ring on the sawed hole.
    Many woodworkers have used a router on aluminum to trim against a template so this is far from a radical idea. Use WD-40 for lube.
    FYI: A fly cutter in a drill press is a terrifying thing. Without controlled feed as in a mill the chance of snagging the bit are high and the results won't be pretty.
  16. #13
    Oct 2019
    72
    17
    Quote Originally Posted by Scottl View Post
    An Idea I had not given any thought on but a Very Good Idea...
    You got me thinking in another direction Thanks
    Paul
  17. #14
    Jan 2005
    Houston
    7,142
    1335
    4145
    I agree.... a flycutter in a DP is not gonna fly. Well, it will fly....
    The annular cutter runs slower and is a balanced cut....that's why it might work.
    But nothing beats a lathe for an easy, good cut....assuming it's a circle you want.
  18. Likes JohnEvans liked this post
  19. #15
    Nov 2019
    CANADA
    Ontario
    668
    1068
    161
    this would literally take 5 minutes in a shop with a cnc machine.
  20. #16
    May 2020
    Minnesota
    493
    196
    189
    If you can chuck it or face-plate it on your lathe, grind yourself a trepanning tool.
  21. Likes Leadfootin liked this post
  22. #17
    Oct 2019
    72
    17
    Unfortunately the piece of aluminum wont chuck up in the lathe chuck
    Its a large piece shaped like a triangle 11.5 x 12.5
    I might be able to rig something up on the cross slide which what ever I do there will be weighed out having a local shop cut it for me...
  23. #18
    Jan 2013
    New England
    108
    21
    15
    Hougen saw.
    Carbide hole saw.
    Not sure if the make the size you need.
    Sent from my SM-G950U using Tapatalk
  24. #19
    Jul 2012
    Minnesota
    40
    27
    11
    If you are thinking of using a hardware store FLYCUTTER be aware. MANY of these things will not stay set. No matter how well you tighten the set screw securing the cross arm, vibration will work things loose.
    Of all the tools in any shop the inexpensive FLYCUTTER may be the most dangerious!
  25. #20
    Jun 2012
    Michigan
    14,079
    4804
    5077
    One old-school way is to center punch the location. Use a compass or a trammel to draw/scribe the finished size and another circle to draw the drill holes. Then drill -drill- drill till you can knock out the slug. then finish to +- .003 or so with a round-sided flat file.
    Very likely any drill press fly cutter will be a turkey shoot and not as good as by hand.
