1400 RPM, .001/tooth/revolution, .050 cuts.
1400 rpms on a .25 endmill is under 100sfm. That in and of itself should not cause a meltdown.
.001" per tooth. That's hardly a chip... Where is your heat going??? Into the chip, and then
beyond the chip thickness into the material.. Over and over again, and eventually you get a
melt down.
FEED IT!!!! Just like dry cutting steels, you want all that heat IN THE CHIP, and GONE!!!
You don't want to push the heat ahead of the cutter, you want to slice it off and toss it
into the chip pan..
If I don't touch any aluminum for a while, I find myself under feeding, its a different
animal than most steels..
Dig up some of ExKennas Ripper mill vids. 6061 dry, at stupid speeds.. The trick.. BIG chipload.
I'll link a vid I made.. I think I was feeding .018" a tooth at around 2000sfm, 6061.. Worked like
a champ.. The cutting part.. Avoiding HOT chips down the collar, not so much..
Just for fun some day, see how hard you can feed in aluminum.. Take a piece
of scrap and just keep upping the feed..
Another story.. Many moons ago when I first got to play with real machines.. Just to see what
it was capable of (Mazak FJV20).. Regular old 4 flute 1/2", .25" depth, .25 width (I think, it
was a long time ago).. Max revs 12k.. And just kept upping the feed. Maxed out at 706 or 708 ipm.
About .015 a tooth. The machine didn't have any more feed, so started backing down the revs while
keeping the max feed. Got down below 6k, .030 a tooth, then we got bored and went home.
I'm 99.9% sure, based on my own experiences, that a thicker chip will cure your melt down problems,
especially at such a low surface speed.
