Mud
- May 20, 2002
- South Central PA
Rookie questions from an old fart here. A customer has asked us to make 2 sample parts from brass, otherwise identical to the parts we make for him out of aluminum. The total amount of brass chips I've made in 50 years would be unlikely to fill a cigar box, about all I know is the warnings I've read about it grabbing drills during drilling. Can you give me a little guidance here?
Part is 6" dia X .625 thick, involves a little milling around the OD and face of the blank for preparation, drilling 6 .875 through holes and 6 .192 through holes, counterboring those 12 holes, then turning and face grooving one side, flipping and turning the other side, then drilling and tappng a 3/8-24 hole in the center. We've done thousands of these on 6061-T6 and have the process pretty much optimized for aluminum with insert mills and drills and a couple HSS tools in the VMC, and CNMP inserts and Iscar groovers in the lathe. Can I run the same speeds and feeds and coolant on brass? Do I need to reduce speed and feed for brass? Do I need different tools altogether? Customer is sending 2 pcs of material and expects 2 good parts in return, seems it's pretty expensive. What trouble can I get into here? Appearance is critical on the finished parts. The .192 holes are counterbored to .625 dia, the bottom needs to be nice, and the turned surfaces need to be nice. No SF requirement, just good looking, possibly polished in use.
