Cutting Hole through 3/16'' 306 Stainless
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
    Feb 2020
    CANADA
    British Columbia
    Exclamation Cutting Hole through 3/16'' 306 Stainless
    Good Day
    I am in the process of building an instrument air test bench. I'm looking to find a hole saw or punch set that is capable of creating a 2 1/2" hole in a 3/16" thick (and what I beleive is) 306 Stainless bench.
    I have tried a greenlee ultra cutter, that is allegedly for cutting steel, but the teeth have already worn out.
    Any tips for getting through this stuff?
    Kevin
    Feb 2020
    Kansas
    22
    50
    9
    Aug 2004
    Virginia
    2,471
    180
    980
    I don't think any Greenlee panel punch is going to do the job. They are made for pulling holes in relatively thin mild steel. It sounds like you may be lacking in the tool department so if it were me I would drill a series of holes and connect the dots. File it smooth when you are done or use a carbide bur to clean it up.
    Nov 2017
    343
    229
    231
    Most likely 304 S/S. 306, AFIK, is not a thing. The cutter was probably up to the job but the speed was way too fast. Calculating (CSx4)/D, (40x4)/2.5= 64 rpm. I'm assuming you were using a hand held power drill? Even a Bridgeport won't go that slow. Punching that hole would take more tonnage than you can muster with a wrench/knockout punch (I've forgotten the calcs on tonnage). Even the hydraulic power-pack punches are limited to about 10 ga. in mild steel, less in stainless. A mag drill with rota-broach might be an option except 300 series stainless is not magnetic.
    I'm thinking you might have to plasma an oversize hole and make a lighter gauge bezel ring to fit, then bolt or weld it to the table.
    If this stuff was easy, anyone could do it.
  5. Likes atomarc liked this post
    Jan 2017
    Oregon
    3,630
    768
    2511
    Quote Originally Posted by KGM View Post
    ...I have tried a greenlee ultra cutter, that is allegedly for cutting steel, but the teeth have already worn out.
    Looking at that Greenlee hole saw, it doesn't really look up to the task. They describe it as made for cutting conduit.
    You've already burned up one hole saw, there's a good chance you've work hardened the material. (It's probably 304 or 316, no such animal as 306.)
    Get a couple Lenox bimetal hole saws, flip the piece over and work from the other side. Go SLOW, lean on it, and use lots of cutting oil. It will dull, so when it stops cutting, switch to a sharp one.
    Nov 2019
    CANADA
    Ontario
    83
    17
    11
    Good Day
    Kevin
    Id be looking into getting it cut out from a plasma or water jet or laser. When you get to that size, hole saws just aren't economical.
    Oct 2016
    Florida
    357
    825
    229
    Watch this video on drilling SS
    YouTube
    And then a Greenlee should do it
    Got to clamp your work down solid!
  9. #8
    Dec 2012
    Se Ma USA
    1,744
    139
    950
    I would laser cut. But I have a laser.
  10. #9
    Mar 2009
    Eureka, CA
    3,981
    843
    1465
    Kevin,
    Welcome to the forum. That material work hardens pretty easily and using a hole saw too fast will be the kiss of death. Annular cutters that large are very expensive and you would need the proper drill or machine to utilize one. I don't think a Greelee punch would make it through 3/16" stainless.
    I would try another, new hole saw using the same pilot hole, but from the other side of the material if possible. Run it slow, keep it cooled and see what happens. You may have to switch to a new hole saw part way through the chore but the trick is to go slow, keep the saw cutting, don't let it skid without making chips or the material will harden and kill the saw again. Slow and good pressure on the drill to keep it cutting.
    Stuart
  11. Likes morestainless liked this post
  12. #10
    Aug 2005
    Tucson AZ
    6,476
    9970
    3040
    Still waiting for details of "306" stainless.
  13. #11
    Virginia
    31,386
    7561
    9846
    Good Day
    Kevin
    Unlikely you even have acess to anything SLOW enough and with the "push" to make a hole-saw or annular-cutter do the do. Believe it or else, HAND rotating a cutter with a tommy-bar or ratchet and a draw-up bolt instead of a pilot could get through that sheet more rapidly than too-fast-burn-it-up POWER. See Old Skewl pipe threading, et al. Tedious, but it let even High CARBON Steel dies last for years.
    As a table or bench top can be a tad unweildy and waterjet and laser are not necessarily "portable"?
    Cheap and cheerful is a skilled hand with a plasma cutting rig that usually IS "portable"..
    Your failed hole-cutter attempt is the line to follow. Clean-up the sharp edges and burrs with air or electric die grinder.
    Insert nice-looking bezel ring.
    Go do something more difficult.
  14. #12
    Mar 2007
    wisconsin
    156
    215
    144
    Last month I needed to cut a 1.25" hole through some 1/8" mystery grade stainless sheet for a car project. I used a cheap Dewalt hole saw. Kept the rpms down, kept it cutting, and a few squirts of cutting oil. I also sandwiched it between two pieces of 3/4" oak to help guide the saw at the beginning of the cut.
  15. Likes atomarc liked this post
  16. #13
    Virginia
    31,386
    7561
    9846
    Quote Originally Posted by paulz View Post
    3/4 pine - or plywood scrap - wudda done easily as well, 3/8" ply, even.
    Seasoned White Oak - commercial high-grade stair treads right useful all-around - can ruin a hole saw easily as fast as Stainless, if not faster.
    Oak just ain't all that happy with cutting fluid nor oils, yah expect to USE it for sumthin' cosmetically decent.
    Shop air can help. Cold weather, yah can even get free shop heat, yah ain't keerful? Mind the smoke, though...
  17. #14
    Jan 2012
    Midland, Texas
    1,563
    565
    800
    I hate fly cutters, but I think that might be a good option for you, IF you have a drill press. Go slow, don't force it. Cut part way through, then flip it over and cut from the other side. Do NOT attempt this if you are using a hand held drill!
  18. #15
    Virginia
    31,386
    7561
    9846
    Quote Originally Posted by steve45 View Post
    More better you should KEEP ON "hating" fly-cutters than to attempt to use one on grabby SS without a seriously stiff and stout rig back of it!
    Better-off to nibble the b**tch with an oscillating saw, brazed carbide grit blade. BTDTGTTS.. rectangular cutout for an ignorant electrical outlet, to be precise as to a safer, if slower Pain In The Ass.
  19. #16
    Mar 2009
    Eureka, CA
    3,981
    843
    1465
    BILL,
    Your nutso syco-bable is going to drive the OP over the edge for Gods sake! It's obvious you haven't been there..or even remotely done that, or you wouldn't be saying the shit you're saying. Give this guy a break and let him succeed (or fail) on his own.
    Stuart
  20. Likes Gordon Heaton liked this post
  21. #17
    Jul 2006
    Hillsboro, New Hampshire
    9,305
    2205
    6453
    Given the OP's lack of experience and equipment, I'd think a single-edge flycutter would be a poor choice for cutting this hole. Even a good drill press doesn't have the spindle/column stiffness needed to maintain uniform edge-to-part relationship, and without a center spigot maintaining centration it wouldn't take much to have an offset-induced grab and break.
    From everything I've read so far, I'd go with drill a periphery of smaller holes and file/grind the hole round. Lowest entry bar, relatively safe (with good eye protection), and doable with basic tools and skill.
  22. Likes Mtndew liked this post
  23. #18
    Jun 2006
    Kansas
    1,507
    286
    564
    My vote is to chain drill it and clean it up with a die grinder and file.
    I cut a rectangle hole in a 11 gauge panel using this method worked good.
  24. #19
    Jun 2016
    New York
    1,891
    1232
    905
    2 1/2” is just not that big a hole, shouldn’t be a problem with a Couple of 10$ BI metal hole saws like a Lenox. Yep, go slow, use lube! A decent cordless on low, and use maybe 1/2 of that low speed at the most. Starting from the backside is good advice.
    The cleanup after “chain” drilling would really be a pain.
    Fly cutter, no, don’t do it! In 3/16 S/S I wouldn’t do it on the BP mill even.
    I’d still use the holesaw. Gullets get jammed up with swarf so you need to peck a lot, but you can’t beat the price. (Yes, it’s not a tight tolerance tool, I know!)
    That is too big for the “smaller” more common magnetic drills, and as mentioned the annular cutter is like 100$ or more, (non-magnetic surface isn’t a problem tho, just clamp a steel plate to it).
  25. #20
    Aug 2004
    Virginia
    2,471
    180
    980
    Many years ago I worked in a machine shop filled with European machinists. It was actually a company based in Hamburg Germany. Most,if not all,the machinists used a mixture of 12/1 water/epsom salt for drilling stainless. This was over fifty years ago and I still use it today. For those dyed in the wool skeptics out there...try it and see for yourself.
