CatMan
Hot Rolled
- Apr 12, 2005
- Brandon, MS
I've got some manifolds that I need to make up. They will be made from 3 1/2" pipe.
I've got a DoAll 500SNC saw to cut the miter joints. Luckily all the miter joints are on a 45 degree angle.
The ones where I'm drawing a blank are the ones where each end is mitered. Sometimes the mitered ends are perpendicular to themselves too.
So how do you keep your angles lined up? Tack a piece of angle iron to the pipe before you start? Thus establishing a "plane" you can refer back to (as in measure or level off of)?
Do you eyeball a weld seam on the pipe and go from that?
Lots of the searches I do turn up results to cope pipe. I'm not looking for that. I can make the cut, I'm just not sure how to hold the orientation of the pipe. Ideas welcomed.
