Cllewellyn22
- Mar 26, 2019
I have hundreds of 3/16" non hardened steel round rods to cut. I just got a dewalt cold cutting metal saw and have run into problems cutting my material. I have tried an 80 carbide tooth blade and a 120 tooth blade. Both blades have the same outcome. When I try to cut the rods 6-8 at a time the blade catches the rods and bends them and hacks up my rods. Does anyone have any tips on how I can fix this issue. Is this a clamping issue? I also tried cutting 6 round rods flat on the deck with a piece of wood on top to prevent the kick back from happening but it still happened. If I tape the rods together will this make a difference if so what is the best way to hold this in the clamp so I don't get hit with shrapnal. I have cut one at a time and it cuts the rod but it seems like it wants to kick back on me. your help is appreciated
