CrustyJuggIerz
- Jan 24, 2020
Hey everyone. Im using a manual mill and I'm looking to cut an oring path thats not a simple circle on a face. I'm trying to cut a groove around a water block for a PC, and while the straight edges are dead simple im throwing ideas around about how to do the radii.
My ideas so far are:
An XY table on top of a rotary head to move the cutter to beginning of the rad, offset it accordingly to the centre of the rotary head and then rotate it as desired (a lot of articulation but could be done)
Or, if such a tool exists that allows you to offset the cutting head eccentric but allows it to be indexed around Z, think mill boring bar head but instead of the whole fixture rotating, the fixture can be indexed to whatever angle and the cutting head rotates at a certain offset, if this makes sense to people.
Does anyone have experience with this issue? Any help would be appreciated.
