Cutting threads on an older TOS lathe.
Page 1 of 2 12 LastLast
Results 1 to 20 of 38
    May 2021
    CANADA
    British Columbia
    9
    Default Cutting threads on an older TOS lathe.
    New to the forum...
    A few yeas ago I acquired an older TOS sn45b lathe. I’ve used it quite a bit here and there making pins, bushings, tools etc. A good addition to the field line boring part of my business.
    Lately I set about to cut some threads. I have the procedure down, or so I thought. The resulting threads are beautiful but the pitch is wrong. All I have is my familiarity with this machine but I don’t have much in the way of documentation. The change gears seem right.
    Set the machine up by the table on the machine. Obviously, I’m making a mistake somewhere.
    If anyone out there have some expertise with this procedure on this machine I would appreciate any help offered.
    Thanks in advance.
    Tom
    Mar 2010
    Davidson NC USA
    1,537
    634
    951
    Measure the number of threads on your workpiece, per inch. Refer to the thread chart on the machine to see if this pitch is enumerated on the chart. You may have selected the wrong pitch on the gearbox.
    May 2021
    CANADA
    British Columbia
    9
    Thanks.
    Do you have access to a TOS sn45? I was actually hoping someone would so I could explain just how I have the thing set up..
    But I did do as you suggest and where I was trying for 8 tpi I actually cut 9 1/2 tpi. Which does not show up on the chart. However I suppose it could be a metric pitch.
    I just don’t know.
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,219
    1056
    782
    You have a good clue. Somewhere is a wrong gear. I am not familiar at all with your lathe, but on many there is a gear driven by the spindle, at spindle speed, which drives the rest of the threading gear train, called the "stud gear". If, perchance your lathe has such a gear and it has 19 teeth or some multiple of 19, and you got with the lathe a spare gear with 16 or a multiple of 16 teeth, swapping those should cure your problem.
    The principles are simple, which is not to say always easy to apply. I would start by measuring your lead-crew to see if it is a metric or inch leadscrew. Obviously to cut 8TPI, your leadscrew needs to turn far enough to advance the carriage by 1/8" for each rev of the spindle. It is just arithmetic...if you can get at the gears to count the teeth.
    Jul 2004
    Houston, TX USA
    32,229
    Might want to get yourself a manual?
    tos sn40b manual - Bing
    have fun
    May 2021
    CANADA
    British Columbia
    9
    According to the chart I need a change gear set with 30, 60, and 127 teeth. That’s what I have installed.
    However I measured a few things as you suggested:
    Lead screw has 4 TPI
    Set up the lathe to cut 8 TPI and rolled the spindle by hand 8 times. Carriage moved just under 15/16 inches (measured with a ruler)
    I can only conclude the change gear set is incorrect.
    Strange that they are stamped with the numbers that the machine chart says I required.
    Perhaps the machine originally had a metric lead screw?
    May 2021
    CANADA
    British Columbia
    9
    Already have that.
    Doesn’t help much.
    Did you think I wouldn’t look?
    Jan 2005
    The Netherlands
    6,737
    371
    1970
    If your leadscrew is 4TPI there should not be a 127 gear in the geartrain to cut a inch thread
    The 127gear is for going from metric to inch or v.v,
    I know the threading chart on those SN machines go bad real quick
    Perhaps they put a new chart on which might be a wrong one for a metric leadscrew
    Try to find a chart for a lathe with 4TPI (That must be one where no Z=127 gear is used for imperial threading)
    Your dials are these metric or imperial Just to verify you have a imperial machine
    Peter
  9. Likes cyanidekid, Red James liked this post
  10. #9
    May 2021
    CANADA
    British Columbia
    9
    Quote Originally Posted by Peter from Holland View Post
    Peter
    Thanks Peter.
    I’m thinking I need the 120 tooth gear. That would advance the carriage a little quicker and make up that small difference between what I’m getting and what I want.
  11. #10
    Mar 2005
    Kansas
    8,618
    604
    4347
    Put up a pic of your gear train and the threading chart. Peter is correct, there should be no 127 tooth gear in the gear train to cut inch based threads.
  12. #11
    Jan 2005
    The Netherlands
    6,737
    371
    1970
    You need the right chart if yours is the wrong one
    Peter
  13. #12
    May 2021
    CANADA
    British Columbia
    9
    Peter
    Thanks again Peter.
    Now that I think of it the 30 tooth pinion drives through a 60 tooth idler and will require a 120 tooth gear at 1/8 the speed of the spindle. You are absolutely right and the 127 tooth gear won’t cut it. Pun completely intended..
    I’m feeling a little stupid now.....but thanks.
  14. #13
    Apr 2009
    Beaver County Alb. Canada
    1,943
    560
    970
    Last TOS i ran had a 3TPI leadscrew.
  15. #14
    Jun 2008
    VA
    809
    210
    326
    A lot of lathes use a 120/127 change gear to switch between inch and metric, having it wrong will give about 6% lead error, not the difference between 8 and 9-1/2 tpi though.
  16. #15
    Apr 2006
    Denmark
    475
    1884
    118
    I own a medium size polish lathe, not a TOS though but an Andrychowska (year 1952 AFAIR). I believe they are similar in many respects.
    I have copied the manual (including a comprehensive thread chart) and will mail it if you're interested. Send me a PM!
    Regards, fusker
  17. #16
    Sep 2007
    Israel
    81
    15
    Chart is already linked in Johnoder post, 127 gear is correct for 1/4 lead screw, check if lead screw shear pin is not broken and slipping.
  18. #17
    Jul 2009
    Munster, In. USA
    2,589
    558
    850
    Did you set up the thread dial for inch threads?
    John
  19. #18
    Jul 2009
    Munster, In. USA
    2,589
    558
    850
    Set correctly the TOS lathe enables the operator to disengage halfnuts when threading both metric and inch threads.
    John
  20. #19
    Dec 2012
    AUSTRALIA
    4,509
    23
    1637
    A 127 or any other gear can be used as an idler,just so as its not driver or driven,or in a compound train......and the multitude of thread pick off gears and two meshing gears is one of the charming results of metric threads being unscientific,and invented by the French.....An imperial leadscrew needs but one gear and one indicator,because inch threads are all logical.
  21. #20
    Jan 2005
    The Netherlands
    6,737
    371
    1970
    Quote Originally Posted by john.k View Post
    If it is used as a idler you are correct that it can be part of the geartrain
    That inch threads are logical is because you guy are used to it and then try to translate metric threads into inch measurements
    For metric threads you best use metric measurement instruments With inch threads the inch units As soon as you translate it it gets complicated
    Peter
    I
