D1-3 Back Plate
Results 1 to 4 of 4
Thread: D1-3 Back Plate
    Nov 2013
    Humble,Tx
    207
    39
    6
    Default D1-3 Back Plate
    Guys I have two 8" chucks one is made over seas which is(I believe) a D1-3,the other chuck is an 8"Cushman with a thread on back plate which I no longer have that lathe.What I like to do is find a back plate that will fit the Cushman so it work on the D1-3 spindle.But the Cushman it has a taper on the inside to line up the back plate with the chuck so I'm thinking that may be a no go,cause I just can't find one.So my next though is maybe machining the original back plate to fit,maybe drill and tap for those 3 camlock pins.I'm somewhat new at this so machining skills are limited,but have access to a mill.Any ideals/thoughts to locating a back plate or where to find the Camlock pins?Thanks for help
    Attached Thumbnails Attached Thumbnails chuck.jpg   chuck2.jpg   chuck3.jpg   chuck4.jpg
    Jan 2005
    Victoria, Texas, USA
    3,816
    1867
    910
    I've done this once on a 6" Cushman 4-jaw chuck that had a D1-3 integral back. Machine the back plate to catch the inside edge of the D1 taper. A 1/4" boss is all you need. Next, drill the back plate to accept 7/16-20 Socket Head Cap Screws. The heads do not need to be countersunk into the back plate if the thickness is not there. Ken
    Edit: IF your worried about the void left from not using a full length nose for the D1 taper. Make you a ring to mount to the face of the back plate to take up the space and give you a more realistic D1 nose if you like.
    Jul 2004
    Houston, TX USA
    29,077
    Chuck back was originally A-5 - see number tag
    Looks like it has been drilled, tapped and counter bored for 4 of the six D1-5" cam lock pins. If the counter bores are 3/4", this is even more likely
    Existing A-5 thru holes - which will be counter bored on face of chuck - are on a 4.125" diameter bolt circle - per ASA/ASME B5.9 Spindle Noses.
    They are for 7/16" socket head cap screws
  4. Likes 4GSR liked this post
    Jan 2005
    3,816
    1867
    910
    Good catch John, I overlookd that on the chuck. Ken
