D1-6 chuck plate made backwards.
Page 1 of 2 12 LastLast
Results 1 to 20 of 23
    Jun 2001
    lancaster,ohio.43130
    927
    18
    138
    Default D1-6 chuck plate made backwards.
    I ordered a small D1-6 adapter to mount a small chuck on a Colchester.I am making it to use soft jaws. The adapter came with the holes on the wrong side of the studs. Is that something new?wrong.jpg0113202039-01.jpg The picture on the left is the new adapter, the right is a chuck with the right adapter.
    Dec 2008
    IL/WI border
    3,360
    1178
    1045
    Isn't it for the chucks that get attached to the back plate (thread is in the back plate) vs the ones where the back plate is attached to the chuck (thread is in the chuck body)?
    That aside, you can always re-machine the holes or machine new ones, of course.
    Sep 2010
    Oklahoma City, OK
    4,690
    806
    1936
    Ya, I do believe those are incorrect.
    Depending on your situation, may be just as easy to redrill them proper instead of returning.
    Apr 2004
    Modesto, CA USA
    7,155
    1219
    I think he is saying to adjust the pins you have to dismount the chuck from the plate to get to the allen head bolts. Not a big issue if it is only used on one machine. But use the same plate on another machine and the pins may have to be unscrewed a turn or two.
    Bil lD.
    Oct 2010
    Oregon
    5,206
    4583
    1895
    Yeah, somebody made a mirror image. As a result, the pins are rotated so their notches cannot engage with the spindle nose camlocks. I confess, it took me a moment to realize why having the retaining screws on the other side would be a problem: because they set the rotation of the pins and the pins require a specific orientation.
  6. Likes Ray Behner, Hopefuldave liked this post
    Aug 2012
    California, Central Coast
    4,044
    2226
    1589
    It looks like the small lock hole is on the wrong side of the pin, so when the pin lines up with the small lock hole the cam slot is pointing opposite the spindle cam.
    I would return it.
    Where did this QC masterpiece come from?
    Just a side note that you do not really need the locks, especially if you dont remove the chuck often.
    Virginia
    28,872
    7561
    8967
    Quote Originally Posted by sfriedberg View Post
    Quote Originally Posted by Rob F. View Post
    THIS! "range of" orientation, actually. They have to be able to rotate just a tad as they are draw-up or released.
    Confusion was 'coz the OP wrote it as if he was on about the chuck MOUNTING holes when he meant the rotation-limiter anchor screw holes were "on the wrong side".
    Ebay "bargain" under 40 US$? Git yer drill and taps out.
    D1-3 is PITA enuf if not rotation limited. D1-6 is too much like work to let 'em float.
    New goods, $70 or more? JF send it back.
  9. Likes Hopefuldave liked this post
  10. #8
    Jan 2008
    New Hampshire
    254
    109
    72
    I had the same problem changing a D1-11 20” 4-jaw on a large Asian lathe. I removed the studs and machined out grooves on the opposite sides with a ball endmill and reinstalled the holding studs using the same lockdown screws in back of adapter. It works fine.
  11. #9
    Virginia
    28,872
    7561
    8967
    Quote Originally Posted by e-fishin-c View Post
    I could actually vote for them making the Metrifuckated plates AND studs & anchors bass-ackwards to reduce confusion. Stud body & camlocks, taper & flat at the spindle are otherwise identical.
    Or meant to be!
    So far, none of my D1-3 or D1-4 ones have been reversed. Just [ US | metric ] stud threads and anchor screws.
  12. #10
    Apr 2016
    Georgia
    112
    23
    31
    Mark what diameter do you need? I've got a couple small d1-6 plates and would donate one to the cause if it'll work for you. Just cover mailing cost. That sucks that it's backwards!
  13. #11
    Jan 2008
    New Hampshire
    254
    109
    72
    These chuck studs can be changed, yours could be easily modified
  14. #12
    Jul 2004
    Houston, TX USA
    30,450
    Scrap. Maker has no clue., never ever looked at or digested ASA/ASME B5.9 Spindle Noses
  15. Likes Hopefuldave liked this post
  16. #13
    Virginia
    28,872
    7561
    8967
    Quote Originally Posted by johnoder View Post
    +1
    High probability the taper and flat are FUBAR as well as the studs, yes.
    ISTR I've had four, perhaps five, D1-3 from Shars or similar - made in China, anyway - that fit up proper.
    D1 have to be "right", but it isn't mission impossible.
  17. Likes Hopefuldave liked this post
  18. #14
    Jan 2005
    Houston
    5,866
    583
    2673
    Would work fine if you run in reverse
  19. #15
    Virginia
    28,872
    7561
    8967
    Quote Originally Posted by GregSY View Post
    Like the toilets in the House of Reprehensibles, Yew-Ass Congress yah mean?
    Messy bizness by the time it splashes out of a Tee Vee screen, that has become.
    I'd guess this pupply would take the UK Parliament approach and simply WOBBLE even if not moving in any definable direction.
  20. Likes GregSY liked this post
  21. #16
    Jun 2001
    927
    18
    138
    GrantA Your mail box is full.
  22. #17
    Feb 2002
    Peralta, NM USA
    5,742
    50
    504
    Am I the odd man out here? All I see is that the studs are going to be off by half a turn, but it's not like the threads in either the plate or stud are timed. I usually end up moving the studs in or out a full turn from the indicator line scribed in the stud and they all fit fine. I don't see that starting half a turn in or out is going to make any difference.
    Just looks funny is all, in my opinion.
    Ah, ok, I'm officially a dumbass. The camlock notch isn't going to line up.
    As Emily Latella said: "Never mind."
  23. #18
    Apr 2016
    Georgia
    112
    23
    31
    Dang sorry I cleared some space
  24. #19
    Jul 2007
    Brookfield, WI
    621
    812
    545
    Easy fix: rotate your lathe 180 degrees. You're welcome
  25. #20
    Feb 2007
    St. George, Utah
    978
    517
    650
    Quote Originally Posted by Ron Hofer View Post
    Nah. That won't work. You have to pull the tailstock through the headstock. Fold it inside-out, like a sock!
  26. Likes sfriedberg, mark costello, eKretz liked this post
