D1 to A1 series chuck adapter
Results 1 to 4 of 4
    Mar 2009
    Brunswick Oh USA
    4,636
    5268
    2767
    Default D1 to A1 series chuck adapter
    Does anyone make such an animal? Looking for a D1-4 to A1-6. Spindle to chuck adapter.
    Aug 2012
    California, Central Coast
    4,436
    2287
    1773
    I would think it would be easy to make one out of a d1-4 back plate or? Just turn the A1-6 taper and drill& tap some bolt holes to avoid the D1-4 pins.
    I did an A1-6 chuck converted to Di-6, even easier,since it had the same taper, just had to drill the chuck for the D pins.
    Mar 2009
    Brunswick Oh USA
    4,636
    5268
    2767
    Quote Originally Posted by Rob F. View Post
    Rob,
    Yes, that's probably what I'll do. Just don't want to.
    Jul 2004
    Houston, TX USA
    30,903
    The trick is to miss other "holes"
    A1 - 6 has BOTH bolt circles that are 5 1/4 AND 3 1/4 - three jaw likely to use the 3 1/4
    D1 - 4" ALSO has 3 1/4 B.C. - complicated by the three adjacent lock screw holes for the cam or lock pins
    The trick of course is to have a THICK enough back plate to accommodate
  5. Likes Ray Behner liked this post
