Dayton Lathe 36"
Likes Likes:  0
Results 1 to 6 of 6
    Sep 2019
    Virginia
    5
    Default Dayton Lathe 36"
    Hi all, new to the forum. I am shopping around for my first lathe. I may have a lead on a Dayton 12x36" I was hoping that someone could give me some insight. I can't find much information on the lathe. It appears Grainger sells them. Anyone have experience with these?
    Thank you.
    Jan 2005
    Victoria, Texas, USA
    4,120
    2339
    1048
    Chinese junk! Or is it a wood lathe?
    Feb 2006
    Indiana
    13,013
    698
    3965
    Dayton is a "house brand" name found on some Grainger products. The lathe is likely imported from China and would be similar to ones with other brand names on them. So assume low quality and, if not brand new, probably not in great shape. Actually, it might need lots of work even if new.
    I bought a new Jet brand 12 x 36 lathe that was made in Taiwan. The cost was around $3000. It looked pretty good when I got it out of the crate. I had to take it partly apart to get it in my shop. Everything I took off exposed horrible workmanship, so that I had to do a partial rebuild before putting it back together. Jet has managed to stay in business, and I see Grainger sells some lathes with the Jet brand along with their Dayton brand lathes.
    Larry
    Sep 2019
    Virginia
    5
    So would it be similar to a precision matthews? Are most chinese lathes very similar?
    I am not sold on this lathe, I am still looking for used american, but having a tough time and the ones I do find either need a lot of work (not best option for a beginner) or are way out of my range.
    Sep 2009
    Phoenix,AZ
    1,838
    2805
    472
    Yep most of the Chinese lathes are very similar,main difference is some are gear heads or change belt for speed changes. Even seen quality differences in the same exact machine from the same supplier ,Monday-Friday builds? Taiwan built ones are usually a bit better quailty wise. I have a 12X36 gear head for the last 15 years no issues -lucky ?? Also have a Clausing 12X36 and have had Logan-SB also in that time frame.
    Virginia
    28,849
    7561
    8958
    Quote Originally Posted by agshooter View Post
    Thank you.
    "Dayton" came from a motor-maker W. W.Grainger bought about a thousand years ago.
    Then they hung the "Dayton" name on anything they could - possible exception a fart in a windstorm. Too hard to catch.
    About 50 years ago ISTR they were selling Logan lathes, but still Logan branded?
    Montgomery-Ward also sold Logans. Far the better machine than the @las Sears-Woebuck carried.
    Decent light lathes, Logans, but "light" they were and are.
    Present-day lathes they offer are identified as "Jet-Elite". Do your own due diligence on those.
