De-burring the back of a blind through-hole
Page 1 of 2 12 LastLast
Results 1 to 20 of 22
    Feb 2009
    Maryland
    166
    25
    25
    Default De-burring the back of a blind through-hole
    Hi -
    Does anyone have any recommendations on how to debur the back of a blind through-hole? I often find myself having to drill blind through-holes in aluminum and then using blind rivets in these holes. It's often very hard, if not impossible, for me to debur the back of these holes, and the rivets seem to prefer for the holes to be deburred.
    Does anyone have any recommendations? Maybe a small file with a tightly curved tip?
    Thanks very much,
    Jon
    Sep 2007
    Central Valley CA.
    210
    A blind thru hole??? Never heard of one.
    May 2007
    Massachusetts
    923
    14
    110
    Is that like a hole half-way through tubing? where the breakthru area isn't easily accessible?
    http://www.youtube.com/watch?v=sAZImFE_cpg
    Jun 2008
    NJ
    293
    14
    29
    sometimes I have to drill a pinhole through a tube of aluminum. I use a reamer to clean out the burrs on the insides of the tube, and a counterbore bit or center drill to chamfer the outsides of the hole
    Jul 2006
    FL
    355
    6
    Apr 2002
    Syracuse, NY USA
    9,823
    19
    619
    the mfg escapes me but another company makes clothespin style tools for small holes, these work very well and will deburr both sides in one pass.
    May 2002
    South Central PA
    14,585
    2821
    4316
    Quote Originally Posted by surplusjohn View Post
    Cogsdill?bbbbbbbbb
    Nov 2007
    Alpharetta, Ga USA
    1,782
    116
    142
    For an inexpensive solution, try Mc Master Carr 4289A41.
    http://www.mcmaster.com/#
    Feb 2009
    Maryland
    166
    25
    25
    Quote Originally Posted by Spelunker View Post
    Sorry - should have been more specific - a through hole, but where you cannot access the back of the hole. For example, if you drill a hole in one wall of a peice of rectangular aluminum tubing - it is a through hole because it goes all the way through the one wall of the tubing; but it's also blind because you can't get to the back side of the hole, since it's in the middle of the tube.
    Thanks again,
    Jon
  10. Likes digger doug liked this post
  11. #10
    Apr 2002
    Syracuse, NY USA
    9,823
    19
    619
    yes, cogsdill, I had a mental block against that for some reason.
  12. #11
    Feb 2009
    Maryland
    166
    25
    25
    Quote Originally Posted by beege View Post
    Neat! This looks like it would solve my problem.
  13. #12
    Sep 2007
    Central Valley CA.
    210
    Ah, a much clearer picture now.
    I am glad you found what you need.
    Cheers
    Kevin
  14. #13
    Aug 2007
    michigan
    554
    8
    Default deburr
    Quote Originally Posted by CS223 View Post
    Our shop has used this type of tool for some time, they work great. We did not use them because of a blind hole , just did not want to turn the part over and do another operation on it and have the operater waist time and labor. They would deburr both sides one shot.
    Ours were not quit like this but close.
    If you want I will find out who makes them.
    ben
  15. #14
    Jan 2003
    Philadelphia, PA USA
    616
    Default Deburring back of hole
    If the hole is near the end of the tubing, use a flat file to deburr. If the hole is not in proximity to the end of the tubing, use a reverse countersink if there is enough room to get it through the bottom & rotate by hand
  16. #15
    Aug 2008
    Murfreesboro, TN. USA
    691
    136
    You can make your own debur tool for deburing a blind hole.
    Lets assume you drilled several 3/8" holes in some square tubing and you need to debur the holes on the inside.
    Turn a pieces of A2 steel in the lathe to about .435" diameter. Turn down the tip end a section about 1/4" long to .350" diameter. Leave a short section of the .435" about 3/4" long and turn the rest of the shaft down to .350" diameter. Both sides of the .435" diameter section needs to have a 45 degree angle so it can debur going into the hole and coming out of the hole. On the end with the .435" section mill a 3/16" slot down the middle of the rod about 4" past the .435" section. Leave about 2" on the end to chuck up in a low speed hand drill. Heat treat the A2 metal.
    Put the tool in your drill. Insert it into the 3/8" hole. The fork end will close up and let the tool go into the hole. The end will spring open once it has passed all the way through the hole. Pull the trigger on the drill and pull the tool back until it touches the hole. You can feel it debur the hole. The RPMS of the drill turning the tool causes enough centrifugal force to keep the tool fork open. Once the job is finished pull the tool out and and your ready to debur another hole.
    You have to make these tools specifically for each diameter hole you want to debur. The large dia. part of the tool needs to be about .060" larger than the hole your deburing. The shaft diameter is clearance. The milled slot only needs to be wide enough to allow the fork to close up and go through the hole.
  17. #16
    Jan 2008
    Worcester, MA
    41
    Smile
    Don't know if you have ever tried it, but cryogenic deburring is good at getting burrs in deep holes that hand tools often cannot reach. If the burrs are light and not too big and thick, then the media should blast them off. Pricing is usually done by the lot.
    We have had success with aluminum and stainless steel metals. Can't run many metals due to possible corrosion from cold temperatures and moisture.
    Take a look here...
    Cryogenic Deburring
  18. #17
    Apr 2008
    MD
    626
    49
    62
    Noga makes reversible countersinks. Can do outside or inside holes. The blade flips open once inside. Pushing (and holding) the button flips the blade back to the narrow dimension parallel to the shaft to get it back out of the hole. Works really well and a super simple idea. Im sure I got mine from Enco or MSC.
    http://www.noga.com/nogaProducts.php?catID=rvcn
  19. #18
    May 2002
    Auckland, New Zealand
    4,666
    2534
    678
    Just an ordinary Noga de-burring tool will get the underside of many holes (i.e. depending on diameter and depth of hole). Especially if you fit one of the slim tips. You simply work from the top side of the hole and hook it onto the underside and give it a couple of turns. An essential tool to have anyway I reckon, so useful on the lathe and many other places.
    smdubovsky, thanks for tip on the reversible countersinks, thats a new one for me. I have been using noga and Varga for at least 25 years.
  20. #19
    Apr 2009
    CA, USA
    Quote Originally Posted by jcorsico View Post
    On that same note, manually:
    http://www.youtube.com/watch?v=U6TIqlekuRU
    www.jwdone.com
    *In the interest of full disclosure, I AM associated with the company.
  21. #20
    Apr 2009
    MI, USA
    7
    Have you found a good solution yet? I work for E-Z Burr Tool and we have great success doing the back side of almost any hole .040 and up.
    www.ezburr.com or send me an e-mail at: [email protected]
