Deburr internal passageways on manifold
Likes Likes:  0
Results 1 to 11 of 11
    May 2015
    New Jersey
    53
    95
    18
    Default Deburr internal passageways on manifold
    I'm working on some hydraulic manifolds with lots of intersecting internal passageways. Some of those are pretty deep in the part and I'm really struggling on how best to deburr them. Currently I'm trying to get in there with a small burr on a dotco, which is very difficult and easy to muck up. Does anyone have any good ways to do this?
    Apr 2018
    6,076
    2911
    Quote Originally Posted by jaguar36 View Post
    Know anyone with an Extrudehone ?
    If not, maybe you could make a feeble one without too much trouble.
    May 2015
    New Jersey
    53
    95
    18
    Interesting, I've not heard of that but I had been kicking around the idea of just dumping some grit into some oil and just pumping it through. Didn't have a good idea on how to keep the grit suspended and also not just destroy the pump. The putty the Extrudehone uses seems like it would solve the first issue.
    Mar 2005
    Kansas
    8,182
    533
    3996
    Look up a process called thermal deburring. I don't know if it would work on an aluminum part. I made steel and ductile iron hydraulic valve bodies that were sent through the thermal deburring process. The process also removed flash rust.
    Oct 2017
    New Hampshire
    115
    98
    22
    Would you be able to “sandblast” the parts with dried ice, walnut, or other media? I’m thinking something other than oxide grit, unless you can flush out the passageways.
    Another alternative would be a vibratory tumbler with any one of several medias.
    I’ve had good results with both of these processes, but also haven’t done something quite as precise as what you’re describing.
    Apr 2018
    6,076
    2911
    I think extrudehones use two cylinders, one on each side, then push-pull push-pull push-pull the paste. If there's no resistance it doesn't deburr very hard.
    If you have enough parts to do, seems like you could rig something up like that ?
    Aug 2004
    Virginia
    2,629
    198
    1119
    Back in the seventies, we had to clean out some SS radioisotope static mixers with intricate channels. We made up a device using a hydraulic press and another old hydraulic cylinder that had screwed on end caps. We would charge the cylinder by unscrewing the end cap. The abrasive was rock tumbling compound that came in four grades in a kit. We made a "slurry" out of the abrasive and white lithium grease. We used the press to compress the loaded cylinder and force the slurry through the mixer. It worked.
    Oct 2014
    Arkansas
    231
    56
    As stated above, look at thermal deburring. I know Sol does it Deburring | Gardena CA | Mechanical Metal Finishing but he's clear across the country. He can tell you what to do.
    Jan 2015
    Missouri
    1,287
    221
    805
    A long lolipop cutter and a debur tool path
    Don
    Oct 2014
    CANADA
    Ontario
    1,535
    1106
    1286
    Cogsdill make a variety of tools that would make this very simple if the geometry allows:
    Deburring Tools by Cogsdill - Originator of One-Pass Deburring
    Many of those have machinable 'noses' so you can shorten up the front of the tool a little.
    A twisted abrasive brush might also be an option if the passages are large enough to allow them:
    McMaster-Carr
  11. #11
    Apr 2012
    Massachusetts
    161
    14
    37
    How about a twisted wire deburring brush? basically just chuck it up in a battery drill or in-situ on the machine and run it down the hole.
