Cole2534
- Sep 10, 2010
- Oklahoma City, OK
I've the need to drill a 1-1/8" diameter 19" deep hole on a 30" C/C lathe, and the material won't fit through the head stock. It also has a blind end.
My plan is to fasten the piece to the carriage and hold the drill in the headstock, but where do I get a 20" long drill? Can I grind the unfluted portion from a reduced shank drill and attach it to an extension? Will this provide enough chip evacuation? The thought process there is that I could feed the drill in to my travel limits, then reset carriage position and bring the drill further out of the headstock. To ensure it starts straight I'm going to bore the first few inches.
The hole is for clearance only, so as long as it's not sticking out the side, we're good to go.
Am I missing any obviously flaws, besides the need for a longer lathe?
