commachines
- May 25, 2016
I need to make a 0.984"(25mm) O ring groove in a part with a 0.610" ID bore (on a lathe). So far I haven't been able to find any ID grooving tools that can make a 0.187" per side groove in such a small ID bore. any suggestions?View attachment 321299
An o-ring you say? It'd have to be a -312, and without seeing the mating parts I'm very suspicious of this component functioning as a seal. Do you have any input to the design? I'd wager that you'll see better performance with a -208 and an appropriately shallower groove, but without seeing the rest of the system I can't say for sure.
Here's what I came up with:
an AS568-208 standard size is a much more sensible cross section than that fatboi specified by your engineer. They can be had from McMaster in packs of 5 for nearly the same price as single o-rings of that other size. If you are stuck with the other o-ring I mathed out grooves for both. Looks like low pressure so the clearance to your tube is non-critical. I assumed your tube is 15±0.1mm for the calculations.
You need more width, both in the groove itself and the walls. I wouldn't be surprised if installation of the fatty blew out those paper thin delrin walls without even considering installation force. If you are width limited then you can cheat a little on the groove and/or walls, but almost certainly need to decrease the o-ring CS in that case.
thanks again for the help...
My engineer is stuck on using the fat O ring as apparently it is more forgiving for any intolerances and will last longer etc...
Since it is a low pressure application, he is suggesting that we make the bore size larger to allow me to use a standard ID grooving tool and avoid the wall blowout in installation. I am limited by space so cannot make the delrin disk any thicker so am stuck with the 0.027" walls... Can you see this working or are we stupid to not go down to a thinner wall O ring as you suggested?
see new dimensions.
Notice
