Sea Farmer
- Mar 25, 2006
- Cape Cod, Massachusetts
I've always understood "work hardening" to mean a material that hardens through either heat or pressure. But a couple of recent threads have used the term in connection with O1 tool steel and stated that it does not work harden.
My experience with O1 in the annealed state is that a bit of friction heat generated by filing hardens it slightly. Same with the heat generated by a bend taken too fast, or grinding. Not the optimal hardness of a proper heat treat, but hard enough to cause some cracking in subsequent operations on the bit that was heated.
Is this "work hardening" or something else?
So is there a formal definition of the phrase?
