Define the term "work hardening"
Page 1 of 2 12 LastLast
Results 1 to 20 of 24
    Mar 2006
    Cape Cod, Massachusetts
    4,660
    1133
    1889
    Question Define the term "work hardening"
    I've always understood "work hardening" to mean a material that hardens through either heat or pressure. But a couple of recent threads have used the term in connection with O1 tool steel and stated that it does not work harden.
    My experience with O1 in the annealed state is that a bit of friction heat generated by filing hardens it slightly. Same with the heat generated by a bend taken too fast, or grinding. Not the optimal hardness of a proper heat treat, but hard enough to cause some cracking in subsequent operations on the bit that was heated.
    Is this "work hardening" or something else?
    So is there a formal definition of the phrase?
    Virginia
    28,005
    7561
    8684
    Quote Originally Posted by Sea Farmer View Post
    Generally applied to any forming operation rather than a heating operation.
    Impact hardening by hammering was essential with copper tools before bronze was discovered, remained essential to hardening bronze at the edges of, for example, a sword, whilst the rest of the blade was held less brittle.
    Also occurs from rolling - Gold springs are made by cold-working - or from rubbing pressure. High Manganese "Hadfield" alloy long used to self-harden a wear-resistant skin on railway switches, digging machinery blade tips.
    Also has to be dealt with when turning, drilling, tapping, milling any 'work hardening' alloy of any race or tribe as the cutter creates problems for itself at any time it rubs or fails to shear cleanly. Have to be a seriously BAD hand-file to do that on bronze, not likely atall on O1. You may not HAVE O1?
    When spinning, goods often require several stops for annealing, lest they become so brittle they crack.
    Ditto bending of even initially very soft Aluminium or Copper. Brass can be far worse than either. Can surface-crack, then through-crack at the point(s) of bend. We rely on that to get the last grasp of lids off tin cans, even shorten fence wire when we have no suitable tools.
    You've actually seen plenty of 'work hardening' already before that O1 walked in the door. Heat, if detectable, is a byproduct, not the cause. Most of it classes as 'cold' working.
    A "formal" explanation and what CAUSES it at the molecular level will be in metallurgy texts. Those you can find online with newer dates than mine - most from the 1920's.
    Bill
  3. Likes old-biker-uk, tdmidget, stonehaven liked this post
    Jul 2004
    Houston, TX USA
    30,217
    Easily demonstrated to oneself
    Get a piece of soft wire, steel or copper would do
    Bend it repeatedly in one place - back and forth
    When it breaks, you have passed the point where it work hardened
    The bending WORKED the metal
    Want to bend less? Start with harder wire - a coat hanger for example, which has already been WORKED some
    Feb 2006
    Indiana
    12,973
    687
    3925
    Work hardening is sometimes called cold working just to emphasize that heat is not a factor. The grain structure visibly changes, and can be seen on prepared specimens under microscopes. They do that sort of demonstration in engineering school, so I have seen it.
    Some metals do not harden when cold worked. Pure lead and pure gold are examples. Gold leaf is an example of a product that depends upon the fact that gold does not get hard when rolled or beaten while cold. A sheet of pure gold leaf will crumple and blow away if you breath on it; it is still soft and incredibly fragile.
    Other metals get harder when cold worked. Think about why some steel products are called cold rolled and others are called hot rolled. Brass can be purchased in states called soft annealed, half hard and hard. The harder states of brass are produced by rolling or extruding annealed brass. The amount of dimensional change in the last rolling operation after annealing controls the hardness. The hard or full hard state has been cold worked almost to the point that further cold work will cause it to fracture. Brass cannot be hardened by heat treating: it can only be softened (annealed) by heating and the speed of cooling does not affect final hardness.
    Larry
    Dec 2008
    New York
    10,234
    2656
    work hardening
    metal stretched, compressed, pounded, pushed to its yield point (bent or deformed permanently) at a lower temperature generally below a red heat or 1400 degree F......... it in general increases tensile strength and hardness of metal and also lowers ductility (ability to further deform without cracking).
    for example pounding on soft copper it gets harder and eventually will crack if you continue to pound on it. by annealing or heating to a red heat or 1400 degree F it will soften, relax the metal to its lower tensile strength , softer condition and higher ductility state
    304 stainless steel that is cold rolled or work hardened can be 2x higher tensile strength and 2x harder to machine. Stainless require a more precise temperature and time heat treat to restore or anneal it without damaging its corrosion resistance
    some metal alloys work harden far more than others. some that are considered do not work harden might work harden a slight amount and so some might say it does not work harden compared to other metal alloys which work harden considerably more.
    Oct 2006
    williamsburg va
    7,882
    839
    1743
    I've had O1 harden while filing. The file suddenly screeches across it,grooving the file. Only hardens a few thou deep,but it can mess up your file when it happens.
    I find it hard to believe that hammering O1 would not work harden it. But,I have not actually tried that.
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,093
    905
    716
    Metal cutting is actually extruding on the microscopic scale, so always leaves a more-or-less-thin work-hardened layer. That is why climb milling and thick chips (high feed-per-tooth) are recommended for metals more prone to work-hardening, like the 300-series stainlesses.
    Can't easily control feed-per-tooth when filing, so as the bevel gets wider, more teeth are in the cut, and the feed pressure-per-tooth declines, you would get into having to cut that work-hardened layer.
  9. #8
    Mar 2011
    Geneva Illinois USA
    6,261
    2704
    2422
    Read these references. You will find more than you really want to know about work hardening.
    Work hardening - Wikipedia, the free encyclopedia
    Tom
  10. #9
    Jun 2014
    Kansas City
    738
    102
    469
    The older I get, the harder it is to work
  11. #10
    Sep 2013
    Orland IN
    181
    33
    When machinists talk about work hardening its usually the material hardening ahead of the cutter
    from heat. It makes it difficult to keep tools sharp or shorten tool life when this happens. 316
    stainless is very bad to do this and your best option is to keep feed rate up and rpms down to avoid
    rubbing the material creating a hardness where you're trying to cut. The materials that work harden I try to avoid
    being a pain to run and go through a lot of tooling if you're not careful. RD
  12. #11
    Dec 2008
    New York
    10,234
    2656
    Quote Originally Posted by gwilson View Post
    i have machined quite a bit of different tool steels. they are often not especially hard but........ many can be very abrasive. hard spots in metal when grain of sand size are bad enough.
    bigger slag inclusions the size of a grain of rice i have seen destroy 40 carbide inserts. the effect is like trying to machine a grinding wheel.
    end mill life machining some tool steels will often average 20 minutes compared to 60 to 120 minute for 1018 steel.
    i would guess O1 problems it might not be strictly work hardening but more abrasive hard spots in the metal
  13. #12
    Virginia
    28,005
    7561
    8684
    Quote Originally Posted by DMF_TomB View Post
    ..would guess O1 problems it might not be strictly work hardening but more abrasive hard spots in the metal
    Wasn't an issue when Timken or Disston were the preferred-source steelmakers, Starrett but a fallback.
    Sure would expect an issue now and then if the metals have made a long sea voyage. Nuthin to do with salt air or seasickness, either. Just origin.
  14. Likes jdj liked this post
  15. #13
    Oct 2007
    detroit,mich.
    4,704
    4710
    418
    Quote Originally Posted by rds6709 View Post
    rubbing the material creating a hardness where you're trying to cut. RD
    Nothing to do with heat. 316 ss cannot be hardened (any more than a point or two) by heat treatment. Friction and pressure (rubbing, that you mention! YES!) are what causes work hardening. High nickel SS and super alloys are the fucking kings of work hardening. O1? Could someone enlighten us as to WHAT element in O1 causes the alleged work hardening? It doesn't have THAT much nickel in it, does it?!?!?
  16. Likes Derek Smalls liked this post
  17. #14
    Jan 2007
    Norfolk, UK
    19,017
    14526
    14620
    Shit! another tip gone!
  18. #15
    Dec 2004
    uk
    14,057
    4552
    6704
    Stainless, try drilling a hole through the head of a forged bolt down the central axis, if you hold the head and drill from the thread end you will know when you hit - get into the forged head area, trust me!!!
  19. #16
    Jan 2011
    Michigan
    110
    54
    Bill
    I'd like to take all of you a bit deeper in just one area of work hardening. A number of steels, especially those used in digging machinery tips have a high percentage of retained austenite in the metallic crystalline structure. As these steels with retained austenite are worked the austenite in the surface layer (which is naturally unstable) instantly converts to untempered martensite. This makes the surface layer file hard but does not affect the softer core material which was not rubbed. Now you have an extremely hard wear resistant surface layer able to withstand the scraping effect of rock. As the super hard layer wears away, a new one forms. Had the same tooth been through hardened to file hard at the start, it would be very brittle and break off almost immediately.
  20. #17
    Sep 2013
    Orland IN
    181
    33
    Quote Originally Posted by jdj View Post
    I'm very interested in this subject so if heat doesn't work harden the material why does my high pressure help. I gave up
    on a 316 ss job when I first starting running swiss that was turned and bored leaving only a thin shell out of .750 because
    It was costing more in tools than the job payed. Later I added high pressure and I tolerate some of those jobs but
    not what i enjoy doing. Running some of the tool steels ,316ss and other can be a real pain. So is friction the only culprit. RD
  21. #18
    Oct 2007
    detroit,mich.
    4,704
    4710
    418
    Too much nickel, not enough carbon and not enough iron in 300 series SS to harden by heat. Friction AND PRESSURE, are the culprits. I machine a lot of 316 ss. The wear that I get on tools, really appears of the abrasive nature. Positive rake tools help to avoid work hardening. Less pressure and more clean shearing action, lessen the stress on the metal. I can get finishers to last well when turning 316, but roughers never last very long...and that is after trying almost every grade and brand of carbide on the planet. I can put a fire hose of coolant on 316 SS, but if the tools aren't sharp and the feed is too slow, it will still harden it.
  22. #19
    Mar 2013
    Missouri
    1,841
    1285
    1002
    . RD
    What is high pressure? hammering?
    You may observe heat in the action of pounding, bending twisting, pressing, rubbing all of them are pushing the molecules around which produces heat which is where all the energy goes to when applying a force.
    Molecular friction a biproduct of using energy isn't what is getting the job done. .
  23. #20
    Aug 2005
    Tucson AZ
    6,406
    9672
    3017
    Heat is more the result of work hardening than the cause.
