RJT
Titanium
- Aug 24, 2006
- greensboro,northcarolina
20 year old piece of equipment,. manufacturer doesn't support it, basically a miniature spur gear that controls the focus adjustment on a vision system. The spur gear is damaged and I need to replace it. I can measure the rack : .032"distance tooth to tooth, tooth depth .024" and included angle of the tooth is 42 degrees. About all I can measure on the damaged pinion is .188" OD and 16 teeth. Can anyone help me define what I need to possibly find a replacement (pitch, pressure angle, anything else I would need) and recommenced a source where I can get it? Somebody like Berg or Boston gear? I can machine a bore or shank or whatever I need to adapt it, but need help defining the gear properly. Rack is OK, just need the gear.
