SculptureCollect
- Feb 9, 2020
I am trying to determine feasibility of the following proposal.
A 3” x 7.1 lb A36 steel channel—12’ long—will be vertically embedded in a poured round concrete pier (15” diameter), so that 3.5’ will be embedded in the concrete and 8.5’ will be above the concrete. The portion embedded in the concrete will be tied to appropriate rebars.
A 1/2” diameter hole will be drilled through the channel web, 1” from the top. A 1/2” diameter 18-8 stainless L bolt will be inserted in the hole, with on each side a washer (2” outside diameter, 1/4” thick) and a nut.
A steel sculpture will be hung on the L bolt, with the load point being about 2” off the channel web. The sculpture weighs about 250 lbs.
Two questions:
Will there be visible deflection in the steel channel?
Does the L bolt appear adequate for the load?
Alternatively, I am considering using a 3” x 4.7 lb 304 stainless channel. (That appears to be the heaviest 3” stainless channel that is a stock item.) The alternative does not have the rigidity of the 3” x 7.1 lb A36 channel, but visually will work better in showing the sculpture.
Question: Will there be visible deflection in the stainless channel?
Thanx!
Two questions:
Thanx!
